TRX Lift, are they out there? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 12-10-2011, 10:42 PM
The Rev The Rev is offline
Vehicle: 2010 Ram 1500
Trim Level: TRX4, Crew, Rambox
Color: Bright With/Mineral Gray
The Rev is on a distinguished road
Default TRX Lift, are they out there?
So I've searched a bunch of old threads, but couldn't find a definative answer. Is it possible to put a leveling or lift kit on a TRX trimmed 2010?
I'm really just looking for a 2" leveling kit, but after seeing on the Rough Country website that their leveling kit doens't fit TRX's I don't want to end up buying a kit from another company that won't work.
Thanks for any help.
Old 12-10-2011, 10:59 PM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
Sure is, you just can't go 2.5". I'd personally look into the Bilstein adjustable struts. All lift kits work with the TRX.
[CENTER][SIGPIC][/SIGPIC]
Old 12-11-2011, 12:02 AM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
As far as I know the only difference with the trx I that it sits about 1" higher in the front then other packages. What I don't know is how they get that 1", I think it's a different strut then what's used on other models which would mean you need to be careful if you use a spacer
There wouldn't be any dufference if umyou used the bilstien adjustables
Old 12-11-2011, 07:26 PM
Blackout Ram Blackout Ram is offline
Vehicle: 2008 Ram 1500 4x4
Blackout Ram is on a distinguished road
I would get the bilstiens, the trx sits up an inch higher probably by like a 3/4" spacer. I highly doubt they would use a different strut. Call Readylift or someone, or take the strut out and see if u can remove the spacer. If u can remove it then u can use a spacer but if not don't do a spacer because you will over extend the suspension. A 2.5 spacer is only about 1.5" tall, so if you go with both that will be too much. I would just go with the bilstiens, there not much more expensive then spacers and are better.
Old 12-12-2011, 10:16 PM
candy08's Avatar
Rep:213
Trx models do use a differet strut to achieve it's .7" lift.
Get the Bilstiens, you'll get the most lift and a better ride.
Old 12-13-2011, 07:55 PM
I stand corrected about the different struts.
Old 12-24-2011, 03:06 PM
Thanks for the info everyone. I went with your advise and ordered the Bilstiens 5100 series for the front and a set of leveling spacers for the rear. I'll let you know how the install goes.
