Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 12-04-2011, 05:47 PM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:912
Default Rear of truck not level left to right
I ordered the Bilstein 5100's for my truck last week, and in preparation for install, i measured the difference in height from the middle of the wheel hub to the bottom of the fender at each wheel to determine how much lift i need to level the rake. to my surprise, the left rear of my truck is a full inch lower than the right rear, and i have less than a tank of fuel (so i don't see it being a weight difference).
Obviously i'm going to ship it back to the dealer this week before changed the shocks out, but i thought id check and see if anyone else has noticed this on their truck to see if it is yet another "it just does it" dodge thing.
I'm no mechanic, but the only thing i could think is a broken spring??
Old 12-17-2011, 04:04 PM
fiveogirl fiveogirl is offline
Vehicle: 2009 Dodge Ram
fiveogirl is on a distinguished road
I noticed my truck leans and is higher on one side than the other. I noticed it after i installed the shocks... was it there before? I dont know?
Old 12-17-2011, 04:05 PM
BTW I also noticed the driver side rear tire is even with the body where the passenger side rear tire sticks out 1.25"
Old 12-18-2011, 02:32 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
As for the lean...I dunno mine does the same thing and it drives me nuts. I'm getting ready to put a 1" spacer in the LR.
As for the tire, you may need a 4 wheel alignment. Have someone follow you and find out if it's following a straight line. Ever see how a dog walks? kinda sideways. Like the rear of it is to either the right or left. If you need a 4 wheel alignment it'll get noticed from behind.
You can try just walking up to a guy and asking him if he wouldn't mind checking out your rear from behind?
Old 12-24-2011, 01:46 PM
I'll give that a try. Thanks.
Old 12-30-2011, 06:25 PM
No luck. The dealer thinks the raising of the rear causes the problem.
Old 12-30-2011, 10:29 PM
Vehicle: 95
Rep:1776
Mine is still stock. I replaced the springs and "U" bolts, and then had a 4 wheel alignment. Still listing to port...I'm at the point that I'm either going to put a 1 inch block in the left rear, or make spacers for the bed.
I don't understand how the dealer could be so obtuse to the problem if everything is stock...the rear isn't raised yet so it obviously couldn't be the root of the problem.
I'm going to do it to remedy a factory problem.
Old 12-31-2011, 03:06 AM
Willbrewer Willbrewer is offline
Vehicle: 2011 Ram 1500 Hemi QC 2X4
Trim Level: SLT- Luxury&Security
Rep:28
Willbrewer is on a distinguished road
Now did you mean to say it that way? LOL
Old 12-31-2011, 02:10 PM
Vehicle: 95
Rep:1776
Without a shadow of a doubt...Oh wait...I do not retain sufficient information to formulate a confirmation, nor a denial of that inquiry at this time. This is a family site.
Old 12-31-2011, 02:26 PM
crusher's Avatar
crusher crusher is offline
Vehicle: 2014 ram sport crewcab rambox
Rep:363
crusher is just really nicecrusher is just really nicecrusher is just really nicecrusher is just really nice
mine is also a inch lower on driver side, went to the dealer and they said it was in the specs
2014 ram sport crew cab with ram box,side steps,sport hood,remote starter,8 speed &3.92 gear lsd,4 corner air susp,knn intake,mufflex 18, BT catchcan,bakflip F1 cover
