Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
tonneaucovered.com
Old 12-31-2011, 03:42 PM
fiveogirl fiveogirl is offline
Vehicle: 2009 Dodge Ram
fiveogirl is on a distinguished road
just a thought.. if you raise the rear end of the truck will the panhard rod not be long enough anymore and pull the rearend toward the passenger side making the passenger side rear tire stick out much further than on the driver side?
Old 01-03-2012, 08:43 PM
tjmjnj tjmjnj is offline
Vehicle: 2011 Ram 1500 4X4
tjmjnj is on a distinguished road
Originally Posted by crusher View Post
mine is also a inch lower on driver side, went to the dealer and they said it was in the specs
Just a thought - sometimes the front left (driver's) wheel is back a bit thus a tad lower to compensate for the crown of the road and to prevent right side drift/steering wheel offset. I know Hyundai did that.
Old 01-03-2012, 09:28 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
^ I never thought of that....could be possible.
We gathered some rear coil spring part numbers a while back and associated them with their lengths and found that most if not all of the trucks (except the RT's from what we could tell...it was a small sample though) had a longer spring on the driver side, by about 1/2" give or take.
Also, with a panhard bar in the rear, yes the axle will "drift" side to slide a little, but shouldn't be 1.25" I don't think. I'm thinking more like 1/2" absolute max.
Sean
