Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 12-04-2011, 08:26 PM
mgeisel mgeisel is offline
Vehicle: 92 d250 diesel
Engine: 1989-1993 360ci (5.9L) Cummins diesel I6 160hp 400lb/ft
mgeisel is on a distinguished road
Default 92 D250 Dash Gauge Lights Not Working
I just picked up a great D250 Diesel. It all works great and still going strong after 310000 miles. The one problem I have if that I cannot get the dash lights to illuminate -- I have checked the dimmer switch and fuses, but still no luck. Any suggestions?
Thanks,
Old 12-07-2011, 12:44 PM
Denman Denman is offline
Vehicle: 1993 D350 Dodge RAM LE
Trim Level: LE
Denman is on a distinguished road
I'd guess the headlight switch; they're notorious for burning out. I think there's a fuse, maybe 3 amps, for the dash lights as well so might be a quick fix, ... I assume you twisted the switch to be sure it wasn't on the "dim" setting.
1993 D350 CTD 5spd Flatbed
Old 12-07-2011, 01:00 PM
moparornocar72's Avatar
Rep:630
My d150's weren't working, i took the gauges apart and lightly sanded the copper that controls the lights and sockets that touch it and then they worked again, just wasnt making good contact!
14.268 @ 95 MPH Full Trim
Old 01-23-2012, 05:43 PM
powerage powerage is offline
Vehicle: 1992 Cummins 2wd
powerage is on a distinguished road
I spent the money on a new (expensive!) headlight switch...had lights for a couple of days...mine keeps blowing the fuse as well though...
Old 01-23-2012, 07:26 PM
Rep:630
Look for wiring that is rubbing underneath where the radio goes, I had this happen and it would blow those lights as well!
