Old 12-04-2011, 11:01 PM
Ryder2011's Avatar
Ryder2011 Ryder2011 is offline
Vehicle: 2002 Dodge Ram 1500 4x4
Trim Level: se
Color: moca?
Ryder2011 is on a distinguished road
Question gettin a p0301 again,what's next..?
after the head gasket change and the brakes ordeal i decided to take the truck to Foley,Al.(5 hr trip) for thanksgiving with my parents and on the way about 150 miles into the drive i noticed that when i acellerated up into an incline i kept getting a stutter( a mild jerking) lol.. and the more i mashed the worse it got,so then i would take it out of overdrive and the rpm's would go up 500-600 rpm's and it would not stutter at all.i had to do this the rest of the trip down..the next day i got in it and went to elberta and it never did it..listen,on flat ground she runs as good as she ever has..well on the way back she started doing it again.on 98 between mobile and hattiesburg there are some tall hills and i just decided to stomp it and go over the next hill,running about 90 at the next top side the engine light came on and stayed on all the way home another 2.5 hours..got home pulled the code p0301,changed the plugs because it needed it probably and she quit doing it and the light went off..but today the light came back on and the stutter is back,and then i pulled the p0301 code,,,, any suggestions as to what's next ???
Old 12-05-2011, 08:21 AM
SuperiorStyles's Avatar
SuperiorStyles SuperiorStyles is offline
Vehicle: 2002 Dodge RAM 4.8L 290ci
Trim Level: Quad Cab SLT
Rep:12
SuperiorStyles is on a distinguished road
Send a message via AIM to SuperiorStyles Send a message via Yahoo to SuperiorStyles
That Code is a Misfire on Cylinder 1 Could be a Coil or Injector so I Advice for you to try to change the coil with another cylinder and see if the code changes. If the code continues then it's time to check the Injector. If you want to know how to just PM me so I can explain Step by Step.
Old 12-05-2011, 10:53 PM
Ryder2011's Avatar
Trim Level: se
Color: moca?
i'll try that tomorrow,i was thinking it could be an injector,had replaced coils on that bank about 8 months ago,still could be a coil though ...thanks,i don't think i can PM you,i have'nt reached that special status yet !! lol
brakes, head gasket, plugs
