Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Dodge Ram Decals
Old 12-04-2011, 11:34 PM
kenmiller59's Avatar
kenmiller59 kenmiller59 is offline
Vehicle: 1999 Dodge Ram 1500 Sport
Color: Dk. Green
kenmiller59 is on a distinguished road
Question AntiFreeze smell from Heat vents......
Hey guys.....I noticed my heat vents smellin like antifreeze and my windsheild foggin up and when I turn my defrost on it is barely warm. Could these symptoms indicate heater core trouble??.......Thanks ahead for your input!!.........................Ken
Old 12-04-2011, 11:42 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PXR Black
Rep:2477
Sure sounds like it could be the heater core leaking is your antifreeze level down on fluid at all ?
sales@revelperformance.com
Old 12-04-2011, 11:58 PM
Color: Dk. Green
Thanks RansRAM!!!!...... Yep.......But not alot.......I can't find a leak though.......Where is it goin??.............Ken
Old 12-05-2011, 01:04 AM
Yep, that's the first place I'd be looking. It doesn't take much to create the smell and it's probably heating to the point of turning into steam, hence your windshield fogging up.
Old 12-05-2011, 08:01 AM
RansRAM's Avatar
Addicted to the Z
Color: PXR Black
Rep:2477
^^^^^ I agree, there is also a drain where the a/c condensation goes (bottom of firewall on pass side)
Old 12-08-2011, 04:24 PM
safetyfast safetyfast is offline
Vehicle: 1996 RAM Laramie SLT 4x4
Trim Level: SLT Laramie
Color: Red/Silver
safetyfast is on a distinguished road
Given the age of the truck, I would give a can of stop leak a try. A friend of mine fixd his by dumping a can of black pepper in his readiator. It lasted for years.
Old 12-08-2011, 07:25 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
I second that.
I'd give a good stop leak a try, just follow the instructions and make sure you turn the heat on to get it to circulate.
Old 12-08-2011, 09:03 PM
Stainless's Avatar
Stainless Stainless is offline
Vehicle: 2011 Dodge Ram
Color: Bright white
Rep:13
Stainless is on a distinguished road
Don't use that stop leak crap, it just makes more problems, get the part that failed fixed, next thing you gonna have a plugged rad and coolant passages.......seen it many times!!!
Old 12-08-2011, 09:06 PM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
The heater core in these trucks constantly circulates coolant. A vacum controled blend door mechanism allows the hot air to be dispensed.
Leaking coolant usually escapes from the floor vents as the core sits in a molded plastic recepticle in the "HVAC" unit.
You can try stop leak, but my experience feels that it creates more long term issues for short term gain.
You're simply going to have to replace the core. It is a pitax3 but can be done with a good selection of hand tools and a good bit of patience.
Several sites (google is your friend) can show you how to do the job without evacuating your a/c.
The best advice I can give is to do the job on level ground, or chock your wheels. Your e-brake and shift mechanism are rendered useless during the r&r.
