Old 01-07-2012, 11:09 PM
DWWHemiguy's Avatar
DWWHemiguy DWWHemiguy is offline
Vehicle: 2012 Ram
Trim Level: Express Quad Cab
Rep:37
DWWHemiguy is on a distinguished road
WEll I looked and my numbers were 802AB drivers and 801AB passengers side.
Old 01-07-2012, 11:12 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Those are numbers from a crew cab.
This is based on a little list we put together from members. I don't know why my quad would have different springs than yours though. And why your quad would have the same springs as someone else's crew...?
Sean
Old 01-07-2012, 11:22 PM
DWWHemiguy's Avatar
Vehicle: 2012 Ram
Rep:37
So if mine were a crew cab would they still be on the correct side? Also is this something I should show to the dealership?
Old 01-07-2012, 11:29 PM
snrusnak's Avatar
Rep:1385
They are correct for a crew cab. And in the correct locations. You are in fact a quad cab right? Not a crew cab?
Let me say that the numbers I'm posting are just what we gathered on this forum from a very small sample of trucks, but from what we found those numbers(802AB and 801AB) were on the crew cabs, and all the quad cabs had what I posted above (801AB and 800AB).
Sean
Old 01-07-2012, 11:39 PM
DWWHemiguy's Avatar
Vehicle: 2012 Ram
Rep:37
Yes it is definitely a quad and not a crew. It's only .5 in. lower so it may be within factory specs. Thanks for your help snrusak.
Old 01-08-2012, 11:17 AM
snrusnak's Avatar
Rep:1385
No problem. You oughta see if someone else on the forum with a sport quad (same wheels and tires as you) would measure top of fender to ground to see if it's the same as yours. Who knows, maybe they match up the springs depending on vehicle weight (depending on how many options it has when built...etc...?) Probably unlikely, but who knows...
Sean
Old 01-08-2012, 05:20 PM
mikeb33's Avatar
mikeb33 mikeb33 is offline
Vehicle: 2012 1500 CC Express 4WD
Trim Level: Crew Cab Express
Rep:14
mikeb33 is on a distinguished road
My 2012 Crew Cab has 803AB and 804AB.
2012 Express CC Black 4WD 3.92 Posi, Bedrug, Backflip G2, Cut rear springs, V6 fan mod, 180 thermo, Diablo Sport
Old 01-08-2012, 05:27 PM
DWWHemiguy's Avatar
Vehicle: 2012 Ram
Rep:37
Are those numbers because yours is a 4x4?
Old 01-08-2012, 05:35 PM
snrusnak's Avatar
Rep:1385
man I don't know, this isn't matching up at all with the numbers we found when we put our list together...
Sean
Old 01-08-2012, 05:53 PM
DWWHemiguy's Avatar
Vehicle: 2012 Ram
Rep:37
This number RRT# 10-036 was posted in the recall/tsb section. Basically what it says is that if your truck is not level, the springs could be incorrect and the dealership may replace them.
