Old 12-05-2011, 09:59 PM
Parts dude Parts dude is offline
Vehicle: 2011 dodge ram 1500
Color: Deep water blue
Parts dude is on a distinguished road
Default Rough country 6" and bilsteins
My question is, the rough country is 6 in the front and 4.5" in the rear. If you have used the adjustable front bilsteins, what height are they set at. I was thinking at the 1.4" lift setting. My truck is a 2011. 3" higher in the rear.
Does this work??
I want the truck level.
Thanks for any input you peoples can share.
Ted.
Old 12-07-2011, 10:26 AM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
Max your Bilstiens out and get a TGC 1" rear spacer and you'll be darn level
[CENTER][SIGPIC][/SIGPIC]
Old 12-07-2011, 10:26 PM
Thanks for the input. If I don't use the rear spacer, then I use use the 2.1" setting on the struts?
Another question for you. What is the ride like in your truck now? About the same as factory, better or worse?
Ted.
Old 12-08-2011, 01:02 PM
candy08's Avatar
Rep:213
It's stiffer than factory, but in a nice way. I have some Bilstein 7100 SBRs that were going to be installed, but they should be a nice improvement over the RCX 2.2 shocks, should be AMAZING
Depends on what your rake is now? The 1.4" would prolly suit you better, the 2.1" would be a Cali lean for sure
Old 12-08-2011, 10:56 PM
I am approx 3" higher in the rear. I am also a 2011. Did the rear lift approx 4.5" as they state? 1.4" would work if the measurements are as RCX says it is. 6 front and 4.5 lift in he rear. Maybe I will go with the bilsteins shocks in the rear also. I don't want to loose to much of the ride quality.
Thanks for yur input.
Old 12-08-2011, 10:57 PM
Your truck looks killer by the way.
Old 12-09-2011, 08:23 AM
candy08's Avatar
Rep:213
Not sure on how much it actually lifted it. when the 6" went on so did the Bilsteins at 1.4" and a .75" RCX rear spacer. This had a little lean, mine now has some lean. But I like the lean, I usually have shit in my bed You won't lose much quality. If you go with Bilsteins for your RCX lift, you want these.....Bilstein p/n AK7114SB. Some of the guys are running 1" spacers and say they are perfectly level, imo as I havent done that setup Sounds about right tho bc I'm anywhere from .5"-1"+ higher depending on where and when I measure hahaha
Thanks
