Old 12-15-2011, 04:09 AM
squig69 squig69 is offline
Vehicle: 15 quad cab
Trim Level: sxt
Color: granite metallic crystal
Rep:13
squig69 is on a distinguished road
Default newbie 4X4 driving question
with this being my 1st 4X4, i was just wondering what speed can you drive with 4X4 on high or lock?
something like "dont drive at more than 50mph while 4 wheel drive is engaged". im asking cuz i dont what to damage anything. is there a speed that you shouldnt drive beyond? thanks
things out of square make me cry
Old 12-15-2011, 04:13 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
chances are if you need to be in 4x4 high speed driving is not what your about to be doing. I believe 4HI will go 70 before it turns itself off and 4 low/4lock should be used for low speed situations only like under 15 lol. I think the manual says what speeds it will work/is safe on parts
2011 Big Horn 4x4 -SnowWhite-
Old 12-15-2011, 07:00 AM
JimmyTheKid's Avatar
JimmyTheKid JimmyTheKid is offline
Vehicle: 2005 Dodge Ram 1500 RC Daytona
Rep:33
JimmyTheKid is on a distinguished road
almost sure snow white covers it to the tee. i personally only use 4x4 high when i drive across the bridge home from groton to new london, its a big bridge and in the north east in a RC sports truck, it kinda tends to get slick.
Active Duty Naval Corpsman - Surface Warfare
2005 Dodge Ram 1500, Daytona, 4x4 RC
Mods: 25% tints, Smoked 3rd Light & Tail Lights, Black'd Out Accents, Black'd Out Grille, HID 8k Fog/Head Lights, K&N Intake System, Black'd Out Rims, Leveled, Diablo inTune
Old 12-15-2011, 04:22 PM
Trim Level: sxt
Rep:13
thanks for the help . reason for asking is when the snow comes im usually out the door before the plows hit the hwy's and if im in 4 lock i was wondering around what speed i should turn it off and return to 2 wheel drive.
thanks
Old 12-15-2011, 04:52 PM
Put it back in 2 HI when you don't need the traction of 4WD...
Old 12-15-2011, 04:58 PM
sethmark sethmark is offline
Vehicle: 2009 Ram 1500 SLT
Rep:19
sethmark is on a distinguished road
4WD High in a part time system like in the RAM can be used at any speed as long as there's a sufficient lack of traction. There's no reduction in 4wd High.
In low range, you'll quickly find out where it will and won't work. There's no speed restriction per se, other than the mechanical one imposed by the rev limiter and the transmission. 30mph at 6000 rpm sucks.
4WD on pavement doesn't work. The front and rear axles don't travel at the same speed and a part time case doesn't allow for differentiation between front and rear. Basically it locks the front and rear axles at the same speed.
Old 12-15-2011, 05:33 PM
SS4Luck's Avatar
Rep:310
thanks
4Hi got me through ~10" @ 40mph no problem with only one wtf is goign on moment, but that was driver/navigator mis communication not the truck lol.
If you NEED 4wd cuz of road conditions I dont see much faster than that being safe regardless of how many wheels you ahve driving
Old 12-16-2011, 04:45 AM
Trim Level: sxt
Rep:13
i re-read my orignal post and it could have been taken that i was asking about off-roading speeds in 4hi, which is not what i meant. does the 4 wheel drive system turn itself off at a certain speed regardless, even if the indicator is still on 4 lock?
Old 12-16-2011, 06:41 AM
SS4Luck's Avatar
Rep:310
I believe 4hi will turn itself off, but i believe that 4 low/lock is governed
Old 12-16-2011, 11:07 AM
gusman's Avatar
gusman gusman is offline
Vehicle: 2013 1500 Quad Cab
Color: Black on Black
Rep:47
gusman is on a distinguished road
Remember to stop and put the truck in neutral before you switch into 4lo (and switching out of it). I also throw it in 1st gear whenever in 4lo, to prevent excessive driveline speeds.
