Old 12-26-2011, 05:49 PM
Rep:2620
CB radio MODS site, use at your own risk of having your door knocked on
http://www.radiomods.co.nz/framescbsite.html
Old 12-26-2011, 10:41 PM
highlandchef's Avatar
Conventional Eccentric
Trim Level: SLT Big Horn
Rep:220
highlandchef, some people don't care for the Cobra all-in-one cb radio
I often work with the California Highway Patrol & i use it as a loaner, as they don't usually have cb radios in the patrol vehicles any more.
Few radio techs know that you can boost the modulation of this radio very easily, i believe that they only put out 3 Watts, even though the package reads 4W.
This radios internal speaker sucks, best to use an External speaker, like i mounted on my suitcases lid
Thanks for the input. In researching the unit I found the video on increasing the modulation and it was obvious from what I read that an external speaker is necessary.
I'm considering it because for me a CB is an occasional need item as opposed to an all the time work necessity for you. It will be used for info on the road, possible emergency if there is no mobile signal or occasionally when traveling with other vehicles. However, I live in the suburbs of New York so when I'm not working it isn't needed and so being able to make it disappear is a good thing. Screw off the whip of the Wilson and no one will know you have a CB.
Old 12-27-2011, 03:15 AM
Rep:2620
This is what i did with mine, i bought the little case at Harbor Freight & made grooves for the wires to lay in when the case is closed & i am using the cb
[IMG][/IMG] [IMG] [IMG] [IMG][/IMG]
Old 12-27-2011, 06:50 AM
Rep:220
That is a great set up. As a loaner or as a field cb that would be perfect.
Old 01-02-2012, 12:15 PM
eltoro2's Avatar
eltoro2 eltoro2 is offline
Vehicle: 2oo9 standard cab 4~4 1500 ram
Trim Level: plain
Color: pearl black
eltoro2 is on a distinguished road
Default C/B use .
whats the point of haveing this set up seams like a lot of trouble just too use the radio , and cumbersome . why have one in the first place . mounted mine in pick up below radio works great just turn it on and pickup mike ??? mounted ant under front hood . no static at all . colt 480 single side band 40 ch well 120 with side band . ex speaker . hello have a hand held cb for out of pick up battery powered.
Old 01-04-2012, 09:36 PM
Rep:220
I believe GTyankee drives escort for trucks with oversize loads and I know he has a CB mounted in his truck. I believe this unit is one he can lend to local police or other local crews they work with who may not have a CB in their vehicle. This isn't the CB he uses.
