Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Dodge Ram Decals
Old 12-06-2011, 06:50 AM
FloridaCracker352's Avatar
FloridaCracker352 FloridaCracker352 is offline
Vehicle: ram 1500 extcab 4x4 1998 dodge
Trim Level: larmine slt
FloridaCracker352 is on a distinguished road
Send a message via AIM to FloridaCracker352
Default battery drain when truck is off
hey guys i need help, a couple weeks ago i hit i big a** bump in the road drove home, turned the truck off then went to bed. the next day i go to leave for work and my battery is dead, i jumped it off my room mates car then went to work, when i turned the truck off i noticed the radio was staying on. i had no clue what would brake to cause this so i had been pulling the radio fuse when i turn it off. the truck sat for the weekend, i go to leave for monday and dead again, so i jumped it once again, then i noticed everything is working electrical wise; radio, wipers, turn signals, a/c ect. what would have broke to cause this??
Old 12-06-2011, 11:08 AM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Is it after market? And did you install the stereo? Cause if it stays on there might be a short between switch/memery power.
Old 12-06-2011, 03:04 PM
im not sure thats the problem, everything has been fine for years, the radio is aftermarket, a sony, which i has been in the truck for over a year. i checked the wires and they're fine.
Old 12-07-2011, 10:26 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
If it was like a Yukon Cornelius WAAAhooo bump...I dunno.
If it was like an (insert multiple explanatives here) hitting the edge of a huge pot hole, bone jarring, tooth chipping bump...I might think that all the stuff in your starter that wears off the inside from normal starts, during normal use, got jarred around and caused a short.
Turn the radio on and the key off. Lay on your back and whack it, the starter that is, and see if the radio goes off.
Jump it and visit the same bump again, or
Climb under there with a test light and see if the trigger wire is hot with the key off.
It's a place to start. Anybody agree with me?
Old 12-10-2011, 05:14 AM
thanks man i want to say from self diagnoses that its my ignition, when its in the locked position it seems to be in acc mode.(when you turn the key back) so i turned it slightly forward of the locked position and it seemed to be fine, but i also noticed when its in the slightly forward position i hear a clicking noise on the drivers side under or behind the dash. any ideas on that? and the wiring plug under the drivers seat could have got wet when the cup hold dumped from the bump spilling 2 cups of soda. and when i move that plug i hear the "clicking" noise.
