Old 12-06-2011, 05:28 PM
Ramathorne Ramathorne is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Color: Deep Water Blue Pearl
Rep:48
Ramathorne is on a distinguished road
Default 305/55/20 Cooper Zeon (and wheel ?)
Anyone know the weight of these tires?
Been looking for a while but have not come across it yet.....
When Spring rolls around I will be looking for a 33" (ish) tire that weighs no more than 60lbs, with a wider footprint.....(pref 305, or maybe a 295)
Or a 33x12.5x20 if the weight is right
Also, going with an aftermarket wheel
If I want something that sticks out about 1" more than factory, what would I need for backspacing etc, on the new wheel???
Old 12-09-2011, 09:54 PM
ScatPak07's Avatar
Rep:970
Just out of curiosity why do you want your tires to be a certain weight? It should say on the site, if not go to BFGs site and check out the A/T KOs. I say this cause they make the same size tire and I believe they have the weight listed. That would give you a good idea of what the tire would weigh.
Also if you look at rims there is an offset number. That number tells you how far the rim will be outward/inward. The stock rims are a +20mm offset. So if you get anything less then that number it will stick out. If you go with a 0mm offset then you will have 20mm outward from the truck. I have -18mm offset rims and they stick out about 2.5" with a 14.5" wide tire. So the rim itself I believe sticks out around 2". All you have to do is convert mm to inch to figure out what the offset will do.
Old 12-09-2011, 10:25 PM
CollateralDamage's Avatar
CollateralDamage CollateralDamage is offline
Vehicle: 2010 Ram 1500 SLT
Trim Level: SLT Plus
Rep:50
CollateralDamage will become famous soon enough
I have a set of the 305/55 r20's and they are heavy man, cant give you a good number other than one of them almost weighs as much as 2 of my blizzaks...
CollateralDamage
2010 Ram 1500 SLT Plus Crew Cab "Mineral Grey"
