Old 12-06-2011, 07:50 PM
Blackout Ram Blackout Ram is offline
Vehicle: 2008 Ram 1500 4x4
Blackout Ram is on a distinguished road
Default Greasable tie rod ends?
Just did a lift level kit on my truck and tore a hole in the passenger tie rod end. I need to get an alignment done but want to replace the tie rod end first. Does anyone make them with grease fittings and whats the best brand? Might be in the wrong section but it had to do with lifting my truck. Thanks
Old 12-11-2011, 04:20 PM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 1997 Dodge Ram 1500 4x4 club
Color: Electric Blue
Rep:210
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
all the aftermarkets are greasable ( moog, duralast...ect... ) Moog is the best but also more expensive, but they all come with lifetime warranty. Even if you go cheaper if you get the lifetime alignment on the truck and have to replace a tie rod later, dont say anything and it will be free to have a re-alignment done. I replaced all of my suspension components before my alignment ( tierods/track bar/ect...) and greased them with a high grade/high temp grease.
Mike
Old 12-11-2011, 06:06 PM
Ok, thanks for the info but when u say lifetime alignment warranty, what do you mean by that? Im doing the tie rod ends myself and then getting an alignment. Im not gonna cheap out on tie rod ends, and lifetime warranty won't help you much if one breaks at high speeds. Do most auto parts store sell Moog brand or where can I find them? Thanks
Old 12-11-2011, 06:57 PM
Rep:2625
I buy my MOOG parts through a wholesale dealer supply warehouse, they supply the parts to alignment shops, repair shops, dealerships & even have a drop off service at peoples homes, in Southern Calif., if you set up an account with them, they carry all the better brands
http://www.wabcoproducts.com/
Advanced Auto Parts & most other Auto Parts stores carry MOOG
http://www.moog-suspension-parts.com/default.asp
http://www.federalmogul.com/en/After...ns/Brands/MOOG
other products made by Federal Mongul
http://www.federalmogul.com/Federal-...ACHEHINT=Guest
