Old 12-13-2011, 12:22 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
The rearend would hold up, it's the same setup used in all the 1500's except the heavy duty's, no reason to worry about that.
I may be wrong but I don't think they made any 4th gen manual 4.7L's. If this is true it would be a big computer problem. I think they made some 3rd gen 4.7L's with manual, which means you should be able to bolt up that gearbox and the same driveshaft. Worst case scenario there is you'd have to have the driveshaft modified to fit which isn't too crazy expensive. The pedal set, master cylinder, gearbox, etc... would/should be easy enough to fit up. The big problem is that if there are not factory 4th gen's with manual, then you wouldn't have a pcm configured correctly to make it all communicate properly. Or maybe since it's manual, it doesn't need any communication so it wouldn't be an issue, I don't know. I know when swapping it is always best to have complete, matching ecm/tcm/pcm's to go with that setup for that year vehicle, otherwise some things may not work (speedo, EVIC, etc...).
Have a link to what you're looking at? I'd love a manual in my truck...
Sean
Old 12-13-2011, 12:33 PM
bobhorn bobhorn is offline
Vehicle: 2011 ram 1500 2wd express
Trim Level: 1500 express
bobhorn is on a distinguished road
Send a message via AIM to bobhorn
Hi Sean, yea American PowertrainSpecialty Performance Parts, 5 and 6 speed Transmission Conversions and Accessories
I'm really considering the changeover again it will need a tuner for it to work.
Old 12-13-2011, 12:41 PM
snrusnak's Avatar
Rep:1385
I don't see a "kit" but I don't know...
Sean
Old 12-14-2011, 03:00 AM
I know there is no Kit per say, but if any one can do it its American Powertrain.
They only need to sell or install one! But As I drive my Ram hard, it just Cuts the throttle any time any loss of traction is detected! Especially with the Rear snows I had to put on for the Winter. We all just have to wait for a Tuner!
Bob
Old 12-14-2011, 09:14 AM
snrusnak's Avatar
Rep:1385
The only problem is the pcm. An aftermarket tuner will not allow you to manipulate enough to reprogram for auto/manual/etc... It only has limited functions.
Sean
