Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 12-09-2011, 09:11 PM
Quiet Lunatic's Avatar
Vehicle: SRT-10
Rep:434
Default 1997 5.2 rough idle hesitates misses
I have a 1997 5.2 4x4. Changed cap rotor plugs and wires. It idles rough and misses/hesitates until 3000rpm all sensors are working and no codes are presant. Anyone have any ideas?
Please help.
Old 12-10-2011, 12:22 AM
Check your throttle body and clean it if necessary. Check your EGR valve clean or replace it if necessary.
Lastly, make sure none of your plug wires are crossed over each other.
Old 12-10-2011, 11:20 AM
Vehicle: SRT-10
Rep:434
I will try both of those today and let you know how it goes
Old 12-12-2011, 01:27 AM
marshall0792's Avatar
marshall0792 marshall0792 is offline
Vehicle: 98 Dodge Ram Reg Cab Long Bed
Trim Level: SLT 4x4
Color: White/Gray
marshall0792 is on a distinguished road
You should recheck the gaps on the spark plugs, one of them could be off.
And you also said you changed the cap and rotor, so you could have possibly messed up the timing when you installed the new parts, not saying you did, just naming off possibilities.
Old 12-12-2011, 12:08 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Missed fire order? Or a wire out of place.
Old 12-16-2011, 10:54 PM
tfs2403 tfs2403 is offline
Vehicle: 1996
Trim Level: slt laramie
Color: blue
tfs2403 is on a distinguished road
If you double checked yourself on all the above try pulling codes see if you are having Cam/Crank sensor issues. Had similar issues and it was my crank sensor.
Thanks and good luck,
Robb
Old 12-17-2011, 02:18 AM
Rep:2890
I found a site that may help you out, it covers several issues with the 5.2 & 5.9 engines
http://www.ramforumz.com/showthread.php?t=99001
