Old 12-10-2011, 08:45 AM
dieselnut dieselnut is offline
Vehicle: 2000 Dodge Ram 2500
Trim Level: Laramie SLT
dieselnut is on a distinguished road
Default Starter Shorting
I have an intermittent start problem. Occasionally, the start solenoid fuse (20A) will blow when I engage the ignition. Replace the fuse without touching anything else, and it will start (sometimes) and then run for days. I recently had my starter checked, and checked for shorts from the starter to the fuse. Any other ideas? Does anyone have a schematic that would help further?
Old 12-10-2011, 03:10 PM
Welcome to the forum!
I assume that your starter lead cable isn't frayed and is connected securely.
So did you check the starter internals???
Here's a link to some wiring diagrams:
http://www.ramforumz.com/showthread.php?t=39992
