will not start! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V6 Specific Topics
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 12-10-2011, 02:49 PM
todd42 todd42 is offline
Vehicle: 2001 dodge ram 1500
Trim Level: standard
todd42 is on a distinguished road
Default will not start!
Battery, starter, ignition coil, fuses are all good. It will not start, it will not even click. You only hear what sounds like a relay moaning. Just got a job and can't afford to pay someone to repair it. If any suggestions, please HELP!
Old 12-10-2011, 03:34 PM
97RAM1234 97RAM1234 is offline
Vehicle: 97 Ram
Rep:24
97RAM1234 is on a distinguished road
Does it even crank over? Mine used to just randomly loose all power and it wouldnt crank over and all I had to do was re position the positive terminal on the battery and it would crank right over.
Old 12-10-2011, 08:00 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
How do you know they're all good?
It could easily be a bad connection. Clean the terminals and re-attach them.
Did you try jumping the starter? (trigger wire to main feed)
Does the battery have CCA?
Neg ground?
Old 12-24-2011, 12:09 AM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:99
Starter relay. That's where I'd start.
Old 12-24-2011, 12:22 AM
Rep:2929
The starter may be hanging up a bit
Try tapping on the starter a bit, don't break the housing
also try jump starting it, you may not have quite the charge needed to turn it over
Old 03-10-2012, 07:50 PM
JB10 JB10 is offline
Trim Level: 1500 2x4 v6 magnum
Color: blue
JB10 is on a distinguished road
Try and put it in neutral and start it. If it will start in neutral then its your park neutral safety switch most likely.
