Steering box? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 12-10-2011, 05:41 PM
toddrod's Avatar
toddrod toddrod is offline
Vehicle: 2001 Dodge Ram
Color: Yellow
Rep:55
toddrod will become famous soon enough
Default Steering box?
Yep ps fluid is coming out of the steering box where it connects to the pitman arm. Anyone ever changed out the box on their own? I can get the part for just under $300, curious about the level of difficulty of this job.
Old 12-11-2011, 04:13 PM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 99 Ram Sport 1500 4x4 Quad
Rep:227
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
I need to do mine as well, a rather simple job as it is pretty accessable, just taking all the lines loose and the mounting bolts/pitman arm. You will need to rent a good pitman arm puller if you do it yourself ( free at most auto part stores ) My cousin has an 01 and mine is a 97 and basically the same on both from what I see. Mine has what looks to be a small oil cooler running off it as I never seen that on anything else before. just 2 extra lines to disconnect. I wont be able to do mine since I am having surgery soon but may get my cousin or someone to knock it out for me.
I Am Groot !
Old 12-11-2011, 04:26 PM
Rep:2929
This may help
http://autodiyonline.com/dodge-diys/...t-general-diy/
Old 12-14-2011, 09:52 PM
tfs2403 tfs2403 is offline
Vehicle: 1996
Trim Level: slt laramie
Color: blue
tfs2403 is on a distinguished road
Hi
I just did one on a 96 Ram. Not bad, I rented a pitman arm puller from the parts store where I got the gear box. Pulled pitman arm, removed 3 bolts through the frame, and the steering shaft disconnected and ur out. Installing the gear box I did in reverse order: I connected the steering shaft then installed the frame bolts and pitman arm last. Make sure ur wheels are straight and your steering wheel is too. The cost of new hoses made the job easier....trying to fight the old hose connections would have made it tough. You may want to consider this if ur hose connections are pretty rusted up. Also make sure you drain the pump and use new fluid. Push new fluid through the system and they make filters to put on the return hose, not bad insurance...... Once you have it up and running jack the front end up and turn wheels from lock to lock to remove air from the system. Do this a couple times then check ur fluid level, it can go down really quick and you do not want to run ur pump dry. All said and done youll be happy you did it yourself.
Good luck!
Robb
Old 12-17-2011, 12:28 PM
toddrod's Avatar
Color: Yellow
Rep:55
Thanks guys this has been most helpful. Plan to do this when the weather warms up. I'll keep you posted.
Old 01-04-2012, 07:56 PM
sonocativo's Avatar
Rep:227
if the box is tight and no play all you need is a new seal kit, pitman arm puller, but if you got play replace it... Im getting ready to do mine...just looking for the labor I cant since I just had surgery and wont be able to for awhile yet myself.
I Am Groot !
Old 01-04-2012, 10:37 PM
Old Dodger's Avatar
Old Dodger Old Dodger is offline
Vehicle: 2006 Ram Cummins SLT
Rep:28
Old Dodger is on a distinguished road
Some years back, I took my '95 2500 in for the same problem. The dealer wanted $700 buck to "replace the seal." I took it down to a local mechanic who did the "replace" for $48.00. When I traded it a couple of years later, it was still as good as new! I would ask a few questions of other mechanics before spending the money! JM2C
Old Dodger Rol Extreme SW MI
SUPERCHIP CORTEX PROGRAMER BESTOP POWER BOARDS PERAGON BED COVER S&B INTAKE BACKUP CAMERA My Favorite Cargo, CASE & INGERSOLL GARDEN TRACTORS AND EQUIPMENT
My Song, http://www.tomrush.com./video_remember.html
