Old 12-10-2011, 06:39 PM
kdgncop kdgncop is offline
Vehicle: 2002 1500 quad cab
kdgncop is on a distinguished road
Default Tire Size/Brand and spacer help!
I have a 2002 quad cab with torsion bars cranked to the max rec spec of 25inches center of wheel to fender. I have put on factory 08 20s. I am now doing a small block lift in the rear.
1st question- what are the best 1/4 inch wheel spacers and where to find? I've seen some on summit website.
question 2 and the tough one. Can I clear a 35 12.50?????? I've read someplaces that I cannot go over 12 inches wide, and other threads say they will. any first hand experience??
I'm looking at nitto trail grappler 295 60 which measures 34.5x12.1. I like the 295 65 which is 35.5x12.1 but i'm afraid it will be a little tall.
What are the thoughts from the pros here??!!
Old 12-11-2011, 02:50 AM
Rammin's Avatar
Rammin Rammin is offline
Vehicle: '03 Dodge Ram 1500 2wd
Rep:44
Rammin is on a distinguished road
35's will fit but depending on what you do with the truck will determine if/how much you will rub. 12.5" wide with a spacer and you'll be fine.
If you're a street only "mall crawler" guy then you'll be fine. If you actually wheel the truck or anything offroad you might have some clearance problems.
Either way cranked bars or a leveling kit and 35s have a stuffed look. Some like it and some don't.
