United Radio
Old 12-11-2011, 09:52 AM
Snoochie Snoochie is offline
Vehicle: 2013 Dodge Ram 1500
Color: True Blue
Snoochie is on a distinguished road
Default 08 Ram Suspension Upgrade and leveling??
Hi! I'm new to the forumz. My truck hit 41000 and the front outer tie rods went and also my driver's side shock is blown. Bad news, anyways im replacing the tie rods no big deal. Do the outers need to be pressed on? Im thinking of going with Bilstein's 5100 all around. Im thinking since im doing all that I should just level the front end out. I need a good recomendation on what to use? Also I heard when leveling some people had other issues with the front end. Is this true?
Old 12-11-2011, 01:36 PM
Wes1500's Avatar
Wes1500 Wes1500 is offline
Vehicle: 2006 Dodge Ram 1500
Color: Black/Silver Two Tone
Wes1500 is on a distinguished road
I have a 2.5" Readylift kit on my 06 1500 and when in 4wd it shakes because of the CV angle; which effects 06-08 models. But in 2wd just daily driving I don't have a problem. The Bilstein 5100s are adjustable and can level your truck so you won't need spacers or anything. But if you do choose to have spacers as well; I recommend the Readylift, Hell Bent Steel, or even Top Gun Customz. The spacers come in 2.5" or 2" depending on if you still want a rake if you tow and depending on if you're puting bigger tires on or not along with what size.
Old 12-12-2011, 03:14 PM
Color: True Blue
So if I used the 5100's and didn't use a leveling kit would that still affect the cv angle?
Old 12-13-2011, 01:37 AM
Kylesmith20's Avatar
Kylesmith20 Kylesmith20 is offline
Vehicle: 2007 Dodge ram
Kylesmith20 is on a distinguished road
i just instaled the 5100 all the way around on my 07 1500 and set them at 2.8 and they are great in 2 wheel or 4wheel. no shake at all and levelled it right out
Old 12-13-2011, 08:22 PM
ebernal ebernal is offline
Trim Level: slt crew 4X2
ebernal is on a distinguished road
I am new to this also, so I really don't need a leveling kit to level my 06 Ram? At local shops where I live it cost about $300 for kit with install plus an extra $90 for an alignment. Would it be cheaper for the shocks plus install?
Old 12-16-2011, 02:09 PM
Wes1500's Avatar
You don't have to buy a leveling kit. You can just get Bilstein 5100s and they will level it out. Price depends on who you go too. I got my leveling kit for $230 (with install $265) and an alignment for $75.
Old 12-17-2011, 09:53 AM
BluePatriot7 BluePatriot7 is offline
Vehicle: 08 Dode Ram
Rep:29
BluePatriot7 is on a distinguished road
For those with bilsteins up front did you find the highest setting being a little nose high? I noticed on some of the 2.5 spacers the nose seems to be a hair higher than the rear. I tow a 16' boat and even though it's not real heavy i dont want to bad of a reverse rake look. Has anyone had the 4wd shake issue with the Bilsteins? Thanks and sorry for the thread hi-jack
