Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
MOPAR DECALS
Old 01-01-2012, 11:24 PM
APSTRAM's Avatar
APSTRAM APSTRAM is offline
Vehicle: 2016 Ram 2500 Crew Cab 4x4
Rep:89
APSTRAM will become famous soon enough
I have not yet added the sales codes to activate the console. I am holding off until I add fog lights and brake controller so I can have all of the codes added at once.
If you are unable to find the complete wiring harness did they at least send the connector end for the lights and the module so you can run your own wires?
Old 01-15-2012, 07:14 PM
APSTRAM's Avatar
Rep:89
I have completed my installation. The homelink worked as expected just needed a fused b+ and ground. The wiring harness already had the lin bus wire connected to the cluster and the display worked without any programming needed.
The compass is a different story. Since it is not an available option on my truck the dealer could not add the code to my VIN.
Old 01-15-2012, 08:44 PM
jmr's Avatar
jmr jmr is offline
Vehicle: 2016 RAM 1500 Express QC 4WD
Trim Level: Express Quad Cab
Rep:77
jmr will become famous soon enough
Has the dealer added the EVIC cluster sales code to your truck?
I've heard that they cannot add all the sales code to a vehicles config, it has to be done at the factory.
'16 RAM 1500 Express QC 4WD 5.7L, 8SPD, 3.21 W/LSD Red Calipers, K&N Filter, 4" AirBox Intake Tube, Cabin Air Filter, Leather Steering Wheel w/Radio Controls, Mopar Bed Liner/Mud Guards/Skid Plates, Lund Tri-Fold Cover, Black RAM Emblems, Homelink Overhead Console
Old 01-15-2012, 09:19 PM
APSTRAM's Avatar
Rep:89
The RDZ sales code added to the vehicle during the EVIC swap is actually for the steering wheel radio control buttons. That sales code is on the starscan list as available for my truck and was added without any problems.
The EVIC did work when it was swapped in but there was no way to contol it. The steering wheel EVIC controls worked after the wiring modifications to run B+ power, ground and the lin buss wires to them.
Old 01-15-2012, 09:35 PM
NMBowtie's Avatar
NMBowtie NMBowtie is offline
Vehicle: 2015 Ram 1500 CC 4x4
NMBowtie is on a distinguished road
They added the RDZ to mine as well, it was available and added without issues. The steering wheel controls now work and I can control all functions of the EVIC. I have talked/emailed with someone who has added the EVIC and OH console both, and he said the compass worked once it was wired into the green wiring connector down by the door hinge. I am trying to figure out which wire so I can wire mine in once I find the OH console with the compass module.
Old 01-15-2012, 09:49 PM
APSTRAM's Avatar
Rep:89
The lin bus wire is white with dark green stripe. It is #3 pin out on the compass module. On the other end pop off the drivers side dash cover and right there you find a green plug that runs power to you overhead light. The lin bus white with dark green stripe wire is found in that plug.
Old 01-18-2012, 10:36 PM
APSTRAM's Avatar
Rep:89
Update. My compass has been activated by a local programmer who was able to hook up to my truck and turn on the options for the compass and the premium tire pressure monitoring system showing all four tire pressures instead of just a low tire message.
The only draw back is that if my truck ever needs to be flashed to update the system configuration at the dealer the changes made to activate these functions get erased.
It would be easy to have them activated again if that does happen.
Old 01-18-2012, 10:50 PM
NMBowtie's Avatar
Cool, do you know what codes he added or how he programmed them to work?
On a side note, what year truck is your cluster out of, and does your ERS (manual gear selection) work? My cluster is out of an 09, and since I swapped clusters, I have lost ERS. I hoped it would activate once the RDZ sales code was added, but no such luck. Everything else works as it should, so I am a bit stumped.
Old 01-18-2012, 11:21 PM
APSTRAM's Avatar
Rep:89
No sales codes, those are used by the dealer to program available options specific to the VIN and those options were not available on my VIN.
The programming was done with a lap top through an OBDII plug.
The cluster I found was from a 2011. I wanted to make sure it was the same year as my truck just to make sure it would work.
The shifter display worked from the first time I plugged it in, even before I made the wiring change and added the RDZ sales code. Once the wiring was done I could control the EVIC and the only thing the RDZ sales code was for was to activate the radio control buttons.
Old 01-20-2012, 12:14 AM
NMBowtie's Avatar
Thanks, I guess I will have to swap my original cluster back in and see if the ERS works. If it does, I know it is an issue with the cluster. If it doesn't, I will try to track down where the problem is. I appreciate the input.
console, map light, over head, overhead
