Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Body & Interior
Old 12-11-2011, 05:30 PM
acsmall acsmall is offline
Vehicle: 2006 Dodge Ram Hemi Megacab
acsmall is on a distinguished road
Default My dodge has sprung a leak!
I believe the leak is coming from the sunroof. I have read other posts talking about drainage tubes/holes. The problem that I am having is I can't find these on my truck to check if they are clogged. I have a 2006 Dedge Ram 1500 Megacab. Help soon! It is raining
Old 12-11-2011, 07:49 PM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 99 Ram Sport 1500 4x4 Quad
Rep:227
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
Those tubes are inside the truck, you will have to drop the headliner. There should be 2 ports( one each side ) that the tubes hook to and run over to the side/rear of the body and on most cars through the floor somewhere to drain outside. Not sure if the routing has been changed over the years but the basic location of the hoses should connect to the rear corners of the sunroof. Sometimes the little nipples crack and leak as well but if removing the inner sunroof frame doesnt esxpose it then you will need to drop the headliner. hope this helps a bit.
If you can't run with the Big Dogs, Stay on the porch.
Old 01-24-2012, 10:54 PM
Boatguy Boatguy is offline
Vehicle: 2008 Dodge Powerwagon
Trim Level: Practical
Boatguy is on a distinguished road
The sunroof drain holes are located at the forward corners of the sunroof drain channel. If they are plugged water will spill over the channel into the head liner eventually making its way down through the grab handle fasteners dripping onto the floor. If that is the case, one or both tubes are plugged. Verify by opening the sunroof and see if it is overflowing the drain channel. If it is plugged drop the forward portion of the headliner, secure the corrogated draintube on the channel spigot with a pair of needlenose pliers then blowout with air pressure. Should fix the blockage. Good luck
Old 03-22-2012, 07:08 AM
redneck84 redneck84 is offline
Vehicle: 2008 Dodge Ram
redneck84 is on a distinguished road
I just found this problem in my truck (dripping water out the grab handle) here's the kicker I don't have a sunroof. Its a reg cab 08 1500.
Old 04-01-2012, 11:37 PM
steve s steve s is offline
Vehicle: 1987 Dodge Ram
Color: Grey
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
steve s is on a distinguished road
Good evening just buying a 2006 when i was looking at it interior carpet soaked, no sunroof will get the truck home in a few days, could it be leaking around windows??
