Old 01-21-2012, 11:22 AM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
Moby - Are yours painted on both sides? I am so torn as to how to add flaps to my white '11 CC. Do you have a picture from about 45 degrees looking from the front? About the opposite angle as you've shown here?
I kind of like your painted step bars too. How are they holding up to rock chips and road spray? Hard to keep clean?
Old 08-04-2013, 11:00 AM
K-Bomb K-Bomb is offline
Color: Mineral Gray
Rep:16
K-Bomb is on a distinguished road
For those that used clear film behind the molded mud flaps... Has it held up? I installed the molded flaps a little over a month ago and all four have rubbed a line in the paint down to the primer in a little over a month.
Old 08-05-2013, 05:34 AM
daggertats daggertats is offline
Vehicle: 2011 ram reg cab 4x4
Trim Level: st
Color: deep water blue pearl coat
Rep:14
daggertats is on a distinguished road
i used the tape after i discovered some of the clear coat being rubbed leaving a line . fortunitly is wasnt too bad. i removed them after about 6 months of use with the tape behind them and it wasnt any different than before i used the tape. the tape definitly helped
Old 08-05-2013, 11:37 PM
joebud joebud is offline
Vehicle: 2012 ram big horn
Trim Level: big horn
Color: true blue
joebud is on a distinguished road
I have the molded one's as well. I got a 2" roll of 3M film and lined wheel well lips. Remove the wheel well liners, sprayed paraifin wax,and cut-out plastic washers to go between the metal tinnerman nuts and fenders. I hate rust and the older dodges all start to rust in their wheel well lips. The 3M film works great. I was told it was developed to prevent rotor wear in desert storm.
