Old 10-01-2011, 10:33 AM
Greybeard52 Greybeard52 is offline
Vehicle: 2012 Dodge Ram 2500 Hemi
Color: Green
Greybeard52 is on a distinguished road
Default Swapping a 4.7L for a new Hemi engine
Has anyone swapped the 4.7L for a new Hemi engine? Do you have to put in a new tranny too? Probably. And about how much would this cost with labor. I'm thinking of ways to save money and I love my 09 Ram TRX Crew Cab, but I need more power to pull my travel trailer.
Old 10-01-2011, 11:52 AM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1195
Tranny is the same AFAIK. The outside dimensions are pretty similar as well between the 4.7 and 5.7. So far as I know, You need ECU, Engine, exhaust, Wiring Harnesses etc and it should be a fairly simple swap...everything past the rear of the engine should be the same, and knowing dodge, all of the mounts you need for the intake/fuse box and all that crap should already be where you need them. The ONLY thing I can see posing a problem right offhand is MDS, but if you are pulling a trailer anyway, disable it with a programmer.
US ARMY-RETIRED
2015 Ram 1500 Laramie 4x4 Crew in Blue Streak Metallic Pearlcoat-Mopar spray-in Liner, Mopar Mud Flaps, 20% tint, Mopar Side Steps, Best-Top Tri-Fold Bed Cover, DZ Tailgate assist.
2002 Ford Focus ZTW Wagon-loaded, tinted and tunes. 183k miles and counting...
Old 10-01-2011, 12:44 PM
Color: Green
The guys on Speed Channel are always yanking out engines and putting in big crate motors. Why not me too? Maybe I'll go big and get something that will not only pull the trailer, but also spank a Vette!
Old 10-01-2011, 10:56 PM
Rep:1385
Definitely possible, but by the time you buy the new engine and get it running right (hopefully)....you could have sold yours and bought a hemi cheaper....that's just the reality...
Old 10-01-2011, 10:58 PM
I agree with both responses.
One, that's a pretty decent list of what you will need (plus the right mounts, hoses, belts, etc...) and second, it can be done but the cost may be more than the hit you'll take if you trade in the 4.7 for a 5.7L
Old 10-02-2011, 11:12 AM
Color: Green
I'm giving the Tow/Haul button a try first. Less $$$
Old 10-02-2011, 12:09 PM
ArmyofOne's Avatar
US Army Retired
Rep:1195
The DSP does WONDERS for the 09+ 4.7L as well. For a few hundred dollars, you get the same/better HP/TQ #'s as the 05-07 Hemi, from less motor.
US ARMY-RETIRED
Old 10-02-2011, 01:33 PM
Rep:1385
Not to call you out or anything but I don't think this is correct....I think what you are assuming is the diablo numbers are roughly the same as the SC numbers, which makes sense. So say 50hp, 55lb ft added. And you are adding that to the stock 310hp, 330lb ft. This gives 360hp, 385lb ft. This isn't correct though, because the SC numbers are a MAX gain, not peak gain. the peak gain is about 15hp, 30lb ft if I remember correctly, so it would actually be 325hp, 360lb ft....
Old 10-02-2011, 02:30 PM
ArmyofOne's Avatar
US Army Retired
Rep:1195
Ur right bro, my math skillz=EPIC fail.
You are correct, I was assuming, and it was a guesstimate anyways LOL.
US ARMY-RETIRED
Old 10-02-2011, 05:45 PM
Rep:1385
no worries lol...
With a good intake and exhaust, and the tuner, the 4.7L is right there with the first gen hemi.
HEMI Engine detail! Gron86 Engine Cleaning 14 05-13-2014 01:07 PM
Miniature Engine. Not a Hemi, but impressive! brad12kx Other Vehicle Discussion 4 05-24-2011 08:14 AM
Hemi Engine Cover HKS 2010 Dodge Ram Forum 24 10-20-2010 05:25 PM
Truck shaking when gas is depressed dirtsurferus 5.9L V8 Specific Topics 12 01-31-2010 01:19 PM
5.7 V8 Hemi Engine Zonestar Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 7 09-22-2008 05:11 PM
