Old 12-21-2011, 03:49 PM
rhodav02 rhodav02 is offline
Vehicle: 2004 Dodge Ram 1500 4x4
rhodav02 is on a distinguished road
Default 2 Inch torsion key and 2 inch block?
I have an 04 Ram and I want to lift it. THe shop i went to gave me a option of putting torsion keys in the front and 2 inch blocks in the back. Is this a good way to get a small lift in my truck? or is it even safe for the truck?
Old 12-21-2011, 06:17 PM
Luke243 Luke243 is offline
Luke243 is on a distinguished road
ive got an 04 too. I was thinking of doing the same thing, but ill probably do add a leaf in the rear. it claims up to 2.5 inches in the rear, depending on your current leaf pack, and 800-900lbs more payload. thats a win win. Id go with the add a leaf and if you still want more in the back get a one inch block.
Old 12-21-2011, 08:22 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Your payload can't change, it is what it is from the factory.
Keys are an option but you could get the same effect by just cranking up the torsion bar adjusters
Old 12-21-2011, 10:13 PM
How much can you lift the front using the stock torsion bar adjusters? Are blocks in the rear reliable? Adding a leaf spring, is that hard?
Old 12-21-2011, 10:26 PM
ive never done either but just from watching how to videos and such neither seems harder than the other, and id say adding a leaf is more reliable. and like i said if you still want more add a little block in there
Old 12-22-2011, 04:37 AM
Color: Mineral Gray
Rep:177
You can get 2" with some room to adjust still sometimes 2.5"
Both keys and cranking achieve lift the same way, by increasing tension in the front end. The only advantage to keys is that it allows you to keep the stock adjustability
Old 12-22-2011, 10:25 AM
Will this have any effect on my suspension? I just want a small lift to put bigger tires on my truck. I have stock 20s and im in need of better and bigger tires.HP wranglers suck in snow.
Old 12-23-2011, 11:52 PM
ScatPak07's Avatar
Rep:970
You do not want to go any higher then 2 - 2.5" or else you will have a crappy ride. The higher you crank them the worse the ride will get. If you stay lower then the 2.5 you will be fine, it should be like the factory ride. I had a buddy with a Chevy and he cranked the bars up front like 3" or something and it was BAD haha.
I would suggest going with a block if you want to raise the rear. It is much easier to do and it will be more reliable. If you add a leaf to the rear you will make the ride stiffer and it will feel like a HD truck. With the block you literally place it between the leafs and the axle. It is only 4 bolts on each side. With the add a leaf you will have to take the leafs off and....etc. It will cost uch more to get it installed. Also if you want to make the truck level or not too much rake you should go with like a 1" block in the rear. If you go with a 2" block and raise the front 2" the truck will sit just like it does not just 2" taller. I know most people want to have the truck level and not rake. If you go with a 1" rear only in the rear it will be a slight rake and if you ever have to tow with the truck you have that room to sag a bit. Keep in mind when doing all of this, the more you lift the rear you will end up lifting the front. So if you raise the rear 2" you might get .25" more up front (that just guessing).
I do not see how the add a leaf is more reliable. The rear block is literally a block that is made of steel haha. The add a leaf would be less reliable since it can sag after years and years. I think the block is more reliable and it is cheaper and easier to install. I have both in my truck, I went with the block first and my Fabtech lift kit came with the add a leaf. I would say put the block first since it is cheaper and easier. Also you do not want to lift the rear too much since you are only leveling the truck. You do not want to be really cheap and start lifting the truck like this. You will have such a shit ride you will regret it. Also probably start breaking stuff and spend more in repairs then you would have if you got a lift kit. Keep the front around 2 - 2.5" and the rear around 1.5" to get a nice almost level not too much rake look haha
Old 12-24-2011, 12:23 PM
Color: Mineral Gray
Rep:177
Add a leaf is more reliable because blocks can cause axle wrap and wheel hop which leads to worse things
At 2" there really isn't a difference, when umyou start using larger blocks with bigger heavier tires it becomes more of a problem
Old 12-26-2011, 06:51 PM
add a leaf is much more reliable. it will bring new life to your current leaf pack and help with the sagging old leaf springs
