Old 02-08-2013, 12:20 PM
Classy7272 Classy7272 is offline
Vehicle: 2012 Ram 1500 5.7L Hemi Sport
Classy7272 is on a distinguished road
Default Update
Originally Posted by Classy7272 View Post
Just bought my first Brand New Vehicle (well, kinda) and already having an issue. 8000 miles on my 2012 Ram 1500 Sport (5.7L V8 Hemi) and the battery light will turn on and the gauge will drop down to 1/4. It goes up and down depending on the amount of boost initiated into the engine. AC off, Radio Off...Its stabilizes. Doesnt stall, no issues at the start. Battery with the volt meter reads 14.1 and drops down to 13.5 then back up. Thinking it might be an alternator starting to go bad (Does that happen on a NEW vehicle?!?!). Annoying at best right now, off to the dealer it goes. Any suggestions are greatly appreciated as im in the field and have mechanics at my whim.
Truck went to the dealer on Wednesday and thought I was crazy with my description (normal reaction being a woman in a mans world) and then it happened to them. Took 2 days to figure out the issue, but something to note with all the electrical issues that I'm seeing on the 2012's. My truck has a wiring harness issue! Not something I was expecting on a new truck.
Rental for the weekend and hopefully my truck will be back to its AWESOMENESS by Monday. Other than this issue, Ive had nothing go wrong. ::Knock on Wood:: Had a 2009 Dodge Ram 1500 for years without incident, hoping my 2012 upgrade maintains that reputation.
Old 02-08-2013, 09:34 PM
mckay99 mckay99 is offline
Vehicle: 2012 ram 1500
Trim Level: big horn
Color: mineral gray
Rep:14
mckay99 is on a distinguished road
4000 mls and no problems.great truck and so fun to drive.
Old 02-08-2013, 09:43 PM
Mike W. Mike W. is offline
Vehicle: 1998 2005 2500 diesel 2012 5.7
Trim Level: XLT,XLT, ST
Color: white, blue, brown
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
Mike W. is on a distinguished road
[QUOTE=1) Those front seat headrests are the worst. Not sure how many of you feel the same way but I had to switch the rear headrests to the front. They pretty much made the truck un-drivable from discomfort.[/QUOTE]
I test drove a new 2011 dually in Az. in late '11 and the headrests were so bad I took them off and threw them in the back seat, never thought of switching them with the rears though. Since Uncle Sam left me with 6 bad disc in my neck I'm very touchy there and passed on the truck although I liked it. Drove another dually in Fla. and it was much the same so I figured it was back to GM for me. Then I drove a 2012 at my normal dealer and loved it so next thing you know I have the 2500 and all fits fine.
Old 02-09-2013, 12:33 AM
05cr125r's Avatar
05cr125r 05cr125r is offline
Vehicle: 2012 Big Horn QC
Trim Level: Big Horn 4x4
Rep:116
ya, not crazy about the headrest either. sure would be nice to lean your head back an inch after working all day
Mods; Line X, Bilsteins set at 2.1, Magnaflow 18", Debadged , Cool White LED Interior, LED license plate, Cool White LED reverse, Fronts tinted 20 %, Stubby Antenna,AVS WindowVisors, Black Honeycomb Grille Insert, Green Performance Air Filter,SuperChip
Old 02-09-2013, 07:31 PM
Huntsvillian's Avatar
Huntsvillian Huntsvillian is offline
Rep:15
Huntsvillian is on a distinguished road
Originally Posted by pmay68 View Post
Does anyone have a problem when dropping cylinders causing vibration in the truck? It is annoying and dealer says its normal but my 09 never did it...
I did, but I just put the manual into 6 and the MDS never comes on. In town my mpg is almost identical.
Old 02-09-2013, 07:34 PM
Rep:15
Whenever I got frost on the truck or if it is below -10 my backup sensors all come on even when nothing is behind the truck. When the temperature comes up the problem disappears.The only other thing is that in the snow or slush the tires throw up all the snow or slush all over the side and then it freezes, especially around the back bumper which can be a real pain. I should probably just buy a set of fender flares. It seems that the 20" rims on the Sport sit out further than the wheel wells.
Apart from that nothing at The only other thing
Old 02-10-2013, 02:32 PM
Marc Coratti Marc Coratti is offline
Vehicle: 2012 Dodge Ram Sport Quad 4x4
Marc Coratti is on a distinguished road
Default Mileage???
Hi All
Initially I could get up to 700km on a tank of fuel (96L) when I wasn't towing anything....but lateley (last couple of months) I've barely been getting around 400km....is this normal???
It wasn't this brutal of a difference last winter....the truck only has 27,000km on it
Any help??? Cause the dealer didn't find anything,
Thanks in Advance
Marc
Old 02-12-2013, 09:54 AM
stefanAT's Avatar
stefanAT stefanAT is offline
Vehicle: 2011 RAM 1500 4x4 QC
Color: grey
Rep:13
stefanAT is on a distinguished road
Could be a problem with the O2 Sensor (or Lambda probe, however you call that in the states). If this sensor sends the wrong data to the engine's blackbox it's very likely that you get a very low mileage.
Old 02-12-2013, 11:19 AM
daversv's Avatar
daversv daversv is offline
Gender: Not Specified
Vehicle: 2014 RAM SXT V6 4X4
daversv is on a distinguished road
Mine has 3000 KM and when stopping a a light, you can actually hear and feel the first gear getting in...... sounds really rough.. not a squuueeeek sound but more like a bong sound.... anyone else ????
Old 02-13-2013, 04:07 PM
stefanAT's Avatar
Color: grey
Rep:13
Sure it's the transmission and not the brakes?
