2008 Dodge Ram fuel consumption problem - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 12-15-2011, 04:44 PM
Terrorlol Terrorlol is offline
Vehicle: 2008 Dodge Ram 2500 Heavy Duty
Terrorlol is on a distinguished road
Default 2008 Dodge Ram fuel consumption problem
I got in my truck this morning and started it, getting ready to go to work like usual when I happened to look up at my fuel economy and nearly died. It said 147 L/100km. I thought that was bad! Not even 10 minutes later it had skyrocketed up to 2348 L/100km. I've checked everywhere for leaks and I've reset the gauge many times. I have absolutely no idea what could be going wrong or why that outrageous number is only going up. D:
Old 12-15-2011, 04:50 PM
Do Not rely on that EVIC gauge. It is not a cumulative measurement and only reflects that moment in time. It will change as you drive down the road. You will see the highest numbers at cold idle.
Old 12-15-2011, 04:52 PM
The problem is that I was idling the entire time. I called my friend and asked him what could make it do that and during the 10 minute phone call it was up to that stupidly high number already. D:
Old 12-15-2011, 04:54 PM
oops...I meant highest numbers at idle.
Old 12-15-2011, 04:57 PM
Could it possibly be a problem with the ecu or ecm in my truck? I'm hoping it isn't but it could be a possibility. ._.
Old 12-15-2011, 05:57 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
If I reset mine at idle it goes down to zero which makes since since your not going anywhere, push the clutch in and let it roll and it'll go way up
