Old 01-07-2012, 02:37 AM
Silverstar777's Avatar
Silverstar777 Silverstar777 is offline
Vehicle: 2014 Dodge Ram
Rep:19
Silverstar777 is on a distinguished road
Default Question about 37" tires
I am about to get a 6" lift and level on my 2011 Ram 1500. I have been reading on here a lot to see what people are running, and I really think I would like 37"tires. My question is, for all you who have that setup, do you have any issues? Also, if I stick with 20" wheels, what width, OS & BS am I gonna want? I don't want the tires sticking out too much, but I also don't want them rubbing, either! So, any advice?
Old 01-09-2012, 04:10 PM
Rep:19
Bumpin. No guys with 37's out there?
Old 01-09-2012, 11:02 PM
Schmitz's Avatar
Schmitz Schmitz is offline
Vehicle: 2005 Dodge Ram 2500 4x4 QC LB
Schmitz is on a distinguished road
There's A few guys out there running 37s on half tons sorry I can't help, I'm running 37s on my 3/4 on stock rims I don't have a clue what BS you need on the 1/2 tons to clear all the suspension parts bighorn4life is running 37s on 20s I know
2005 Dodge 2500 4x4 QC LB Hemi, 6 inch lift, 37" Cooper Discoverer STT's, Bully Dog programmer, K&N cold air intake performance throttle body, true duals, debadged.... Soon to come 4.56s and wheels, maybe more lift.
1980 Chevy K20 4x4 9 inches of lift 37" Boggers, 402 BBC, 4 spd, D60, 14ff.
Old 01-10-2012, 12:05 PM
Rep:19
Hey, thanks for the reply.
I came across bighorn4life on the board here. It looks like the setup he has is pretty much what I have been looking at doing. So that is helpful.
Old 01-10-2012, 05:04 PM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
You'll need at least a 5" bs. Thats what I wnated bc like you, I don't like the tires sticking out far. I got suckered into 4.5" bs bc thats all that was availible last March whenI got mine. Honestly now I wouldnt have it any other way. I suggest a 20x10 -24mm offset and 4.5" backspacing
You can run any 37 you want without rubbing issues, depedning on which lift and leveling kit you're stacking. Matter of fact you can even run 38s in the 15.50 flavor depedning what I said above and youre bs.
I should have some 38x15.50x20 Mud Graps here soon. Won't perform half as good as my Swampers but damn do they look good
[CENTER][SIGPIC][/SIGPIC]
Old 01-10-2012, 05:18 PM
Rep:19
haha! Nice! Well, I am looking at a set Toyo open country 37x13.5 tires right now. As for the lift, some shops are offering Pro Comp, others are offering BDS. With those choices, there are different options for leveling the front. BDS offers their 6" lift with both a 5" rear lift and a 3" rear lift. The 3" inch combined with the 6" in the front levels the truck. The 5" would require the front to be raised even more to level it. However, you get 2 more inches of lift that way. As for the Pro Comp, I'm not sure what they really offer or how it actually sets up once on the truck. So, that's where I'm at for now.
Old 01-10-2012, 05:38 PM
candy08's Avatar
Rep:213
Ahh the me-too tire. That should clear just fine.
Are you wanting your truck to sit level or do you want to mess with Bilstiens or a preload spacer? Honestly you're only gonna get an extra 1.3" of lift if you go Bilstiens. Both BDS and PC use 4.5' strut spacers up front for your lift and 1.5" worth of preload spacers. Those spacers have to be removed for your 2.8" Bilstiens....do the math. With that said, it also depends on if you want to retain the factory springs like PC does or if you want new lifted coil springs. Also PC reatins the factory rear arms with use of a dropdown bracket, BDS uses a bracket that goes above the axle. The PC drop bracket is a full drop though. However they are also the only company not to supply you with a skidplate But they do supply you with a kicker bar kit where BDS does not.
My kit is alot like Fabtechs. Both have taller strut spacers (we're taller with Bilstiens), we have skidplates, we have kicker bars, we have new adjustble and greaseable rear arms and lifted coil springs. Everything else is the same.
BTW we have done clearance measuremnts. Me (RCX), Bighorn4life (BDS), MuscleMcKeester (Pro Comp). Pulling this from dodge talk......Also on that thread we have pics with the tapes for proof of course!
RCX 6" lift Bilsteins set at 2.8" 37" Super swampers
17.5" ground to crossmembers
15" ground to Skidplate
BDS 6" Bilstein set to max 2.8" 37" Nitto Trail grapplers
16.5" ground to Crossmembers
12.1" ground to Skidplate
Procomp 6" lift Bilsteins 2.8" 37" Mudd Grapplers
16" ground to Crossmembers
13.125" ground to Skidplate
Mopar 4" lift
13 7/8" to crossmember and 9 1/4" to skid plate
Old 01-10-2012, 05:51 PM
Rep:19
Wow, the stats are interesting! Honestly, The PC stage 2 lift has caught my attention. It uses an adjustable coil over up front and has upgraded shocks in the rear. Really, I am looking for 3 things: 1. I want the 37's to clear 2. I want the truck to sit level and 3. I don't want it to look stuffed. So far every truck with a 6" lift and 37's I have seen on here looks good! By the way, did all those kits raise the rear the same amount?
Old 01-12-2012, 02:30 AM
candy08's Avatar
Rep:213
No, the rears are all lifted different heights and deifferent ways as well. I like how you explain every lift! Why the 2700 buck coilover setup tho? PC uses all spacers and stock rear springs to lift the back end....
BTW I know darn near everything about every lift. Especially how each company lifts and what and how they use their components to achieve that lift. If you have any questions plz ask.
My buddy was looking at this same lift, PC Stage2. He recently saw the light and changed his mind tho He will be lifted by the end of the month Also have another buddies 6" lift, bilstiens, wheels and tires out in my garage. His is going in the air next month when he gets back from underway. My house is gonna be real cute with 3 2011 crewcab sports in diff colors all lifted on 37s hahahaha
Old 01-12-2012, 11:54 AM
Rep:19
Well, I suppose I have a bit of a bias against RCX lifts. I had one on my Jeep wrangler and after a while, the springs had sagged half the height of the lift. Other than that, it was fine. I am kinda getting hooked up with a good deal on the PC lift by a friends shop, so I went ahead and ordered it up. I did like the setup of the BDS and the RCX too, but it looks like PC will be the way I go.
