Old 12-15-2011, 10:49 PM
crusher's Avatar
crusher crusher is offline
Vehicle: 2014 ram sport crewcab rambox
Rep:363
crusher is just really nicecrusher is just really nicecrusher is just really nicecrusher is just really nice
Default catch can installation stupid question
Ok i feel very stupid... Ive install ths catch can on the engine now what hose goes to it... Is it from the drver side head to the catch can and catch can to air intake?? The instruction i got are for the jeep srt8...it say to look at passenger side head...
Thanks for the help
2014 ram sport crew cab with ram box,side steps,sport hood,remote starter,8 speed &3.92 gear lsd,4 corner air susp,knn intake,mufflex 18, BT catchcan,bakflip F1 cover
Old 12-15-2011, 10:57 PM
Your PCV hoses go into the can. One from the head or valve cover, the other from the PCV valve.
Old 12-15-2011, 11:13 PM
crusher's Avatar
Rep:363
Originally their is one hose from driver side valve cover to the air intake then a second from passenger side far in the back to the throttle body... So wich one would it be
Old 12-15-2011, 11:19 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
It should be the one from the passenger valve cover to the TB. There should be a pcv valve on that line near the valve cover (or right there at the valve cover). The other line from the driver valve cover to the airbox should be just that, a line, with no pcv valve. I'm not sure why there are two lines (1 at each valve cover) but I would guess the one without the pcv valve sucks in fresh air and the one with the pcv is obviously the "vent".
Sean
Old 12-15-2011, 11:30 PM
crusher's Avatar
Rep:363
So if i get this right.. The line from the back of passeger side valve cover/pcv valve that looks lile a black box to the throttle body... I cut it at half. Put the rubber hoses on them to connect to the catch can and voila... They other line stays untouch
Old 12-15-2011, 11:46 PM
Rep:2664
[IMG] [IMG]
Old 12-15-2011, 11:51 PM
snrusnak's Avatar
Rep:1385
That should be correct. I will say though I don't have the hemi so I'd wait for someone else to respond as well...
Sean
Old 12-15-2011, 11:54 PM
crusher's Avatar
Rep:363
Thank you allfor the help...
Also very nice pics
rep points for all of you
Old 01-15-2012, 09:24 PM
Ramfd's Avatar
Ramfd Ramfd is offline
Vehicle: 2009 ram 1500 QC 2wd
Trim Level: Big horn
Color: Brilliant black pearl
Rep:150
ok here is another question, what does a catch can do, and why should i get one?
Old 02-12-2012, 04:14 PM
Rambunkshuss's Avatar
Rambunkshuss Rambunkshuss is offline
Vehicle: 2014 Dodge Ram
Rep:87
Rambunkshuss will become famous soon enough
[IMG] [IMG]
GT,
where did you buy your catch can from... how much did it cost... ???
Did it come with those stainless braided hose`s too... ???
Thanks
Life`s tough, its even tougher if you`re stupid
