Front Drive Shaft CV Joint - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 12-17-2011, 03:24 PM
fxdrider fxdrider is offline
Vehicle: none
fxdrider is on a distinguished road
Default Front Drive Shaft CV Joint
It appears the CV joint on the front drive shaft (rear part of shaft, entering transfer case) is going bad. Clicking noise when I turn the front wheels by hand, and a "whirring" sound that varies with vehicle speed when I'm actually driving the truck. I've seen the repair kits (Auto-zone calls it a Driveshaft CV joint and Napa calls it a Propeller shaft repair kit), and was wondering how difficult a job is this? I'm comfortable changing u-joints, wheel hub assembly, etc. Would this be something that's doable? I can't find any directions for it online, not even You-tube. Anyone know?
Thanks.
Old 12-18-2011, 09:49 AM
Vehicle: none
Anybody have any idea?
Old 12-18-2011, 02:50 PM
Vehicle: none
Seriously? No one with a 3rd Generation Ram has experienced this problem with their front drive shaft?
Old 12-22-2011, 10:09 AM
Vehicle: none
Can ANYONE help me?
Old 12-26-2011, 10:37 PM
dakotaracer47's Avatar
dakotaracer47 dakotaracer47 is offline
Vehicle: 2007 Dodge Ram 1500
dakotaracer47 is on a distinguished road
Not me, I'm getting a squeaking sound from the left front but think its a wheel bearing, started to squeak faster last week on the highway...Sorry!
Old 01-11-2012, 10:36 AM
Vehicle: none
UPDATE: When I push up on the rear of the front drive shaft where it enters the transfer case, there's a bit of play - probably about 1/8". Seems to me that might indicate the front bearing in the transfer case is bad.
I called my dealership for a quote on replacing the bearing, and the service rep told me it would make more sense to replace the entire transfer case, as Parts & Labor on both jobs were withing $200 of each other, and the case replacement would come with a 3 yr/36,000 mile warranty - whereas the bearing replacement alone would only come with a one year/12000 mile warranty. The price for the transfer case replacement, by the way, was $2300.00. Man, these are expensive toys.
Old 01-17-2012, 10:25 AM
fireman21 fireman21 is offline
Vehicle: 2013 Ram Big Horn Quad
Color: deep cherry Red
fireman21 is on a distinguished road
well all bearings are allowed a certain amount of play. you need to determine exactly what is moving and making noise. hold the side of the cv join that goes into the t case and move the ds up and down. if there is play then it may only be that u joint and you would be good to go. if there is no play then its only the bearing. check with a place like aamco or something for a better price. shop around at reputable places. most good shops will give you a warranty also. but a bearing replacement is definitely something i dont suggest you do yourself.
Old 01-21-2012, 08:08 PM
Spectre Spectre is offline
Vehicle: 2004 Hyundai Elantra
Spectre is on a distinguished road
If the CV boot has been torn for a significant amount of time, it may be best to go ahead and replace the whole thing. Was your CV boot torn? If it was, was the cv joint dry? I wouldn't do it myself unless I had something very sturdy to raise the truck with.
Old 03-15-2012, 05:18 PM
dead2fall dead2fall is offline
Vehicle: 2004 Ram 1500 SLT 5.7l Hemi QC
Trim Level: SLT QC
Color: Blue
dead2fall is on a distinguished road
My cv boot is torn and joint is dry. Get a whole new shaft or??
Old 10-05-2012, 04:13 PM
Bigkatt's Avatar
Bigkatt Bigkatt is offline
Vehicle: 2002 dodge ram 1500 sport
Bigkatt is on a distinguished road
U can do the cv axle buy yourself I had my wheel bearing go bad which put stress on the axle and caused it to rip.... its not hard to change a buddy and I did it on the side of the highway in a couple hours.... there is a YouTube video which was very helpful just look up cv axle replacement tells u everything u need should change it in a shop doing it on the highway is not safe but I did what I had to do
