Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 12-17-2011, 10:49 PM
dannyh dannyh is offline
Vehicle: 2011 dodge ram
dannyh is on a distinguished road
Default 1995 Ram 2500, 360 cu.in.
I replaced the water pump and during the replacement I discovered a short coolant hose from the water pump, under the alternator/ a/c compressor mounting bracket. Does anyone know how to remove this bracket so that I can replace this short coolant hose while I've got this tore down? I've remove all the bolts I have seen but the bracket will not move. Any ideas?
Old 12-18-2011, 12:20 AM
panhead's Avatar
panhead panhead is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: SLT w/ Sport Pkg
Color: Sollar Yellow
Rep:103
I think, the idler pulley has to come out (between the a/c and alt). I'll have to check tomorrow.
Old 12-18-2011, 01:20 AM
I looked at that that and I could feel behind the pully the bolt does not go all the way through. I can't see anything else hold it but I cannot get it to move. It will rock up and very little but it will not pull straight out or up. Are there any online repair manuals I could looks at?
Old 12-18-2011, 01:26 AM
panhead's Avatar
Rep:103
Its been awhile since I had pulled the acc. Bracket off. Mine came off fairly easy when I did the water pump and plenum plate.
Old 12-19-2011, 07:46 PM
Yes I had to pull the Idler pully off, there is a bolt behind it that can not be seen unless the Idler pully is off. Thanks for the input.
Old 12-19-2011, 11:26 PM
panhead's Avatar
Rep:103
No problem. Hope everything works out man.
