Old 12-18-2011, 09:00 PM
macez's Avatar
macez macez is offline
Vehicle: 1998 dodge ram 1500
Trim Level: st
macez is on a distinguished road
Default Tranny swap
in my 95 ram 1500 i want a stronger trans in it. does anyone know if i can swap out the 46rh for the 47rh with little or no mods?
Old 12-19-2011, 02:46 PM
slimjim slimjim is offline
Vehicle: 99 4x qc150. 95.250 4x 5.9 gas
Trim Level: sport 150, slt 2500
Color: bl or gy
slimjim is on a distinguished road
I dont believe the belhousing will bolt up to your motor. 47's & 48's bolt to a Cummins or V-10's. What are you trying to accomplish? Just to keep from changing your trans with every oil change or are you trying to turn 44" mudders or pull a 12,000 lb trailer? Our dear 46RH transmissions dont fail from overworking they just come apart internally weather they are grocery getters or hard core workers. Your '95 may have a part in the trans cooler line that wont allow fluid to move while truck is in park and that must go. Most agree heat is the enemy to any trans but till your goes drive drive drive!!
Old 12-20-2011, 06:04 PM
macez's Avatar
Trim Level: st
What i am going for is a stronger trans behind my 5.9 because i just rebuilt it .030 over and I am putting in a hotter cam with some valve work done to the heads. The 46 in it now is startin to go so I either need to rebuild or get a stronger trans in it. I would imagine that i could fit a 47 or 48 behind it because the 10 cyl engine is basicly a 5.2 with 2 extra cylinders
Old 01-05-2012, 09:37 AM
Brad750's Avatar
Brad750 Brad750 is offline
Vehicle: 1997 Dodge Ram
Color: Blue and Silver
Rep:27
Brad750 is on a distinguished road
I would like to know if this is possible also. I would like to tow with my Ram and she has the 46. Maybe there is a way to upgrade the internals to 47 standards? Anyone know the differences between the two so I know what to purchase?
Old 01-06-2012, 12:04 AM
macez's Avatar
Trim Level: st
i know there is an upgrade that u can do to make the 46 a little better, it has to do with redoing the valves and i think it has some better clutches in it. i seen it in an issue of four wheeler magazine on the long range clunker project. i was wondering on the 47 because it has the same gear ratio minus reverse, but it just has some stronger gears in it thats y i was wondering about if anyone knew if the swap was capable with little or no mods.
Old 01-06-2012, 12:29 AM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:99
http://www.transmissioncenter.net/dodge.htm
Feast your eyes. They offer a package to upgrade your guts.
Package #K48RZ.
You can't just swap in the V10 transmission. The bellhousing is machined to match the Cummins, not the V8's.Their Viper level 2 would be all you need, and less costly.
Old 01-06-2012, 12:59 AM
The Codes's Avatar
The Codes The Codes is offline
Vehicle: 1998 Dodge Ram
Rep:44
The Codes is on a distinguished road
I have looked into the viper tranny, I wished they just sold the parts, so I could go get them installed local, I feel like that would be cheaper than buying it from them assembled. There is a transmission shop around my area that builds trannys for NHRA people, and specialize in performance trannys not just rebuilding them commercially, and they said that they could rebuild mine into a "bullet proof" and performance tranny for 1600, that sound to good to be true to anyone?
Old 01-06-2012, 01:08 AM
Rep:99
They do sell the guts only. # K3 or #K4. Just scroll down to the combo kits section. The level 2 kit is $618.
Old 01-06-2012, 01:41 AM
The Codes's Avatar
Rep:44
Yeah right after I posted I continued scrolling down and was like crap..haha Ill have to take down a list of those parts and give that shop a call and see how much they would charge for install. I would also be interested in seeing if they could upgrade the kickdown lever to the ratio the hemi trannys use. Be nice to have that extra bump on the highway.
