Old 12-18-2011, 09:11 PM
macez's Avatar
macez macez is offline
Vehicle: 1998 dodge ram 1500
Trim Level: st
macez is on a distinguished road
Default gears
i am running 35s on my stock 9 1/4 rear and dana 44 front. i was wondering what would be a good final drive gear ratio. i was thinking 4.56s. amy thoughts
Old 12-19-2011, 01:37 PM
chrisp chrisp is offline
Vehicle: 05 ram
Color: silver
Rep:12
chrisp is on a distinguished road
whats is the current ratio? i found a converter on another forum and plugged in my info and from going from the stock 245/70/17's to a 35in tire i would need a 4.10 to stay near the same rpm without significant power loss. i myslef would go 4.56 give it a little more umph. heres the link also some cool other converters for you offroaders too
http://wore.ca/smf/index.php?page=53
Old 01-01-2012, 09:54 PM
Leadchunker's Avatar
Leadchunker Leadchunker is offline
Vehicle: 1996 Dodge Ram 1500 4x4,
Color: Green
Rep:57
Leadchunker will become famous soon enough
Yep, I would use the conversion chart that chrisp recommended or you can find another conversion chart. Just remember if you go with the 4.56 you can go with even bigger tires next time.
Chuck
Lawrenceville, GA.
Old 01-02-2012, 05:44 AM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Depends on what your looking for out of the truck. If your actually wheeling the truck go with 4:56, if your just looking to help your truck turn the tires on a Dailey driver 4:10s will be a better ratio
Old 01-02-2012, 12:34 PM
TerrysRam's Avatar
TerrysRam TerrysRam is offline
Vehicle: 2011 RAM 1500 4x4 SLT
Trim Level: Outdoorsman
Rep:16
TerrysRam is on a distinguished road
Isn't stock ration 3:55 on those? I'm pretty sure it is, I had two of 'em.
Like someone else said, what are you looking to get out of it? If it's your DD I wouldn't go with more than 4:10's. If it's only a toy to climb and mud with - 4:56's.
Just keep in mind, if it's a DD you're going to kill your mileage even more than you currently are now with the bigger tires.
Just a reminder too, if you're going with bigger tires, you may want to look into upgrading your braking system too. More meat to stop. Just a reminder.
Rain-X Latitude wipers; Custom bent Magnaflow catback; Volant CAI - with ram air tubing; EGR Vent visors; Line-X; driving lights behind the grill; Silverstar fog lamps; Silverstar Ultra head lamps; WeatherTech mud flaps; American Tonneau Company tri-fold tonneau; Diablo Sport inTune I-1000 DCX
Old 01-03-2012, 03:44 PM
firerescuedodge23's Avatar
firerescuedodge23 firerescuedodge23 is offline
Vehicle: 2007 Dodge Ram1500
Trim Level: SLT (ThunderRoad)
Color: Gold
Rep:59
firerescuedodge23 will become famous soon enough
well i have this same issue, I do mild to moderate offroading and mudding but its also my DD. I have 35x12.50x20 m/ts with the stock 3.92 gears. I'm having a really hard time deciding on whether to go with the 4.10s or 4.56s as well.
AFE Stage 1 intake, Flowmaster 40 series exhaust, Fabtech 6 inch lift, 3 inch PA body lift, 35x12.5x20 Federal Couragia M/t, Full audio system, LSD, HIDs, Superchips Cortex, 20x10 XD Strike -24 offset
Old 01-05-2012, 10:53 PM
macez's Avatar
Trim Level: st
ya as of right now it is my DD but i do some moderate off roading so im stuck between the 4.10s and the 4.56s because i have the 35s now and after i put a 2 inch leveling kit on the front i might think about 37s in the future.
