Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 12-20-2011, 01:08 AM
geebee's Avatar
geebee geebee is offline
Vehicle: 2001 dodge ram 1500
Color: green
geebee is on a distinguished road
Default please help quick reply!
i have a 2001 dodge ram 1500 and i need to know if a 2001 dodge ram 1500 sport driveshaft will fit in my truck. also it is just a half in shorter than original could that mess things up?
Old 12-20-2011, 01:25 AM
Rep:2705
I would only be guessing
But usually 1/2" shorter would not be an issue
do you have your old part that goes into the transmission, the yoke ?
you should be able to look at that & see where it fit into the transmission, it will usually be the shiniest area on the yoke
if it looks like it was in far enough not to fall out, you should be good to go
if it is too close for you, go to a driveshaft shop & get a longer yoke put on
Old 12-20-2011, 01:40 AM
geebee's Avatar
Color: green
its about 4 in in t case and about 4 in out give or take 1/4 in and its same yoke only diffrence is driveshaft from u joint to u joint is half in smaller on the sport model
Old 12-20-2011, 01:57 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
I cannot find different part numbers other than between Manual and automatic transmissions, and those are 1-5/8" different in length, so am thinking the 1/2" difference you have is manufacturing error/tolerance.
brad
Interested in one of my mods?
Old 12-20-2011, 01:59 AM
geebee's Avatar
Color: green
well my truck is manual the truck the shaft came off of is automatic.
Old 12-20-2011, 02:08 AM
Rep:2705
That should not matter if the splines are the same
Old 12-20-2011, 02:25 AM
brad12kx's Avatar
Rep:2581
Did some extra digging.....is yours 2wd or 4wd?
brad
Old 12-20-2011, 02:49 AM
brad12kx's Avatar
Rep:2581
Best I can find is -
The rear drive shaft for your truck, manual or automatic is the same P/N 52105744AA.
The front drive shaft differs between manual and automatic.
brad
