Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 12-21-2011, 09:38 PM
t05ks t05ks is offline
Vehicle: 2011 Dodge Ram 2500
Trim Level: SLT Bighorn
Color: Deep Cherry
t05ks is on a distinguished road
Default 2500 hemi and 5w30 oil
Seeing as the 2500 w/hemi does not have the MDS using only 5w20 should not be a concern. Who amongst us is using 5w30 as the oil of choice for their 2500 hemi? Also, have you noticed a mileage drop? or difference in how the Hemi runs? Thanks guys.
Old 12-21-2011, 09:42 PM
wbowyer wbowyer is offline
Vehicle: 2011 Dodge Ram 1500
Color: Inferno Red
Rep:71
wbowyer will become famous soon enough
I notice you're in MN, I don't see how the lighter weight oil could hurt especially in the colder weather. Might want to bump up to the 30weight during the spring/summer months just to be safe.
Old 12-22-2011, 09:53 PM
Color: Deep Cherry
Truck most likely will not see much of the outside world (or salt) during the winter months. My 96 has now been downgraded to the daily driver. The 2500 will mostly be used for towing during the camping season. I will probably dump in 5w30 for the winter storage so its ready to go in a few long months.
Old 12-22-2011, 10:35 PM
highlandchef's Avatar
Conventional Eccentric
Trim Level: SLT Big Horn
Rep:220
The spec for the truck is 5w20 so there is no reason for the 5w30 in the winter. In fact in the winter your better off with 0w20 particularly if it is going to be sitting quite a bit. I just changed my oil from the Amsoil 5w20 I usually run to the 0w20 even though a drive as much in the winter as I do in the summer.
Old 12-23-2011, 12:43 AM
Rep:2657
I would use at least the oil viscosity on your fill cap & in your owners manual
the first number on the oil viscosity scale, does Not mean a thing, UNLESS it is Winter
like 0 W-** means that the oil was tested down to that temperature in cold weather settings
same with 5 W-**
the W is the abbreviation for Winter
The number after the W- is the actual viscosity of warmed up oil, it keeps that viscosity until it reaches its particular break down point, just before it boils,
Technical speak page, the Last Paragraph says it all
http://www.zddplus.com/TechBrief13%2...0Viscosity.pdf
Old 12-23-2011, 08:13 PM
White Ram White Ram is offline
Trim Level: Lariat
White Ram is on a distinguished road
What does the owner's manual say?
