ecu problem? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 12-22-2011, 01:40 AM
Oatess85 Oatess85 is offline
Vehicle: 1999 dodge ram 1500
Trim Level: Slt
Oatess85 is on a distinguished road
Default ecu problem?
If a ecu is in limp mode will the check engine light be on? my truck has no balls and the mpg is shitty, the truck revs up at start and the the idle will stay high after pressing on the gas pedal while the truck is in neutral. ive replaced all tb sensors, plug wires, cap, rotor, plugs, air filter, oil, transmission filter, transmission fluid, and cat. Or would you say its the throttle body pan gasket?
Old 12-22-2011, 10:19 AM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2014 1500 Eco diesel/1982 D150
Trim Level: Outdoorsman
Color: Deep cherry red
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Rep:21
Was check light on when you replaced sensor's? If so did you reset computer? Or disconnect bat when you did the work? They can still hold the code even after sensor was replaced. If none of this is the case and computer is clean look for vacuum leak.
Old 12-22-2011, 10:21 AM
ramfam's Avatar
Rep:21
Another place to look is iac or air temp sensor both of these will make it idle like crap.
Old 12-22-2011, 01:12 PM
Trim Level: Slt
thanks for your help! i found a vacuum leak and yes the check engine lights where on before and after replacement
