Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Diablo Predator Questions & Info!
Old 12-23-2011, 03:09 PM
artemus artemus is offline
Vehicle: 2009 Dodge Ram
artemus is on a distinguished road
Send a message via ICQ to artemus
Default Need HELP with adjusting throttle sensitivity
I remember seeing somewhere that I could adjust the throttle sensitivity with the Predator. I am running a 91 octane performance tune. I've looked through the Predators menu while having it plugged into the truck with no success. Is this an option with the 91 performance tune? If so, how is it obtained? Thanks?
Now a rant if you will. I have encountered some computer programs and equipment which was not user friendly. But The DS Predator ranks up there in the top 5% range. The company needs to put out a reasonable owners manual with feature and instructions for the Predator. The unit has done a good job in performance. But for the time I have invested in it, I could have had a custom tuner make modifications cheaper and with less frustration.
Sorry to rant, but this is ridiculous. End of Rant
Again, my thanks and hoping you a Merry Christmas
Old 12-23-2011, 03:26 PM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:64
I am not sure on the adjustments(whats available) for the 09 ram, but the throttle sensitivity adjustment is under the modify tune (all 87,91,93 octane) on my 05. I know on my 05, some of the adjustments wont show up unless I turn the key on (don't start engine, parking brake on) then plug my DS tuner in. I only learned that trick after spending the better part of a day reading old posts. Just a thought, since comm issues seem plentiful with DS tuners. Great tuner hands down, if it works as it's supposed to or if you learn the tricks of making it work like it's supposed to. Try Daiablosport.com's forum as well.
2007 6.7 | EFI-Live | Draconian tuned TCM | T4 S366 | ARP | AFE | Thuren | Carli
Old 12-23-2011, 03:54 PM
MADDOG MADDOG is offline
Rep:22
Try Modify Tune. It should be in that section.
I agree with ya...as much as I love the Predator programmer results, getting there can be a PITA.
Old 12-23-2011, 04:06 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
LOL. I feel much better now! Around here, I'm well known for my technical/computer prowess, but was beginning to think my age or something was starting to show, as I found that navigating through the Predator was/is a bit confusing.
I guess I can cancel my tests for CRAFT disease.
brad
Interested in one of my mods?
Old 12-23-2011, 05:35 PM
One other question. Do you have to go into the 91 oct perf tune to get to the modifications for that tune? IOWS, at the main screen, should I go into Predator tunes, select the 91 octane performance and THEN go into the modify tune? Once there, is the item I am looking for marked as "Throttle sensitivity"?
Thanks again
Old 12-23-2011, 09:52 PM
FDBDW's Avatar
FDBDW FDBDW is offline
Trim Level: Big Horn, 5.7 hemi
Color: BRILLANT BLACK CREW CAB
Rep:172
FDBDW has a spectacular aura aboutFDBDW has a spectacular aura about
Its in the same list with, shift points, mds , Rev & speed limiter, fan control ect. If i remember right its under modify parameters. You can always reinstall the tune and select modify before loading, kinda of a pita way to do it. Also if your don't have the latest update it may not be on your tool.
MOPAR CAI , 14" MUFFLEX, Diablo Intune 91oct , 2.5" LEVEL, K2 OPEN BLACK MESH GRILLE, FRONT WINDOWS TINTED, ROCKSTARS ON 295/70/18 NITTO TRAIL GRAPPLERS, LARADO BED COVER, DEBADGED, GO RIHNO STEPS , RECON SMOKED TAIL & THIRD BRAKE LIGHTS , PAINTED HEADLIGHTS , SPEEDLOGIX CATCH CAN, FASTMAN PORTED TB ,
Old 12-24-2011, 10:17 AM
05ram's Avatar
05ram 05ram is offline
Vehicle: 2004 VW .:R32, 3.2l AWD V6
Trim Level: .:R
Color: UGM
Rep:145
05ram will become famous soon enough05ram will become famous soon enough
WOW, this seems a lot more complicated than my SC3865, even with the advance trans tuning(which is time consuming, but well worth the effort). I was thinking of trying a DSP but maybe not.
2008 VW .:R32, 3.2l, AWD, V6, #2952/5000
Old 12-24-2011, 10:56 AM
brad12kx's Avatar
Rep:2581
Thanks again
Yes, you have to select the tune to get to the modify section for that tune.
Have you checked the firmware on the Predator to ensure you have the latest? They are constantly adding new things, so it's a good idea to keep it updated.
Is it marked 'Throttle sensitivity'..... I'd have to hook mine up to see. I'm almost due for an OC, so if I restore my tune before anyone else has an answer, I'll dig through the menus and let you know what I found.
brad
