Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram MPG Zone
Dodge Ram MPG Zone Discuss your MPG woes and helpful hints here!
Dodge Ram Decals
Old 12-22-2011, 03:23 PM
Garballs Garballs is offline
Vehicle: 2012 dodge ram
Garballs is on a distinguished road
Default Gas Mileage on my new 2500 is bad
I have a 2012 Ram 2500 with 5.7 Hemi, the mileage is 11 in the city and 14 on highway driving conservatively. Anyone with any tried and true methods of increasing the mileage by either changing the exhaust, chipping or adding a cold air intake. And, which of any worked the best and with what products?
Old 12-22-2011, 05:18 PM
Intake and exhaust will help a little. Unfortunately, there are no programmers available for your year truck yet. CJD encrypted the PCM software and no one has, as far as I've read, cracked the code yet.
I have an AFE Stage 1 intake, a Magnaflow single in / dual out 18" muffler and a DiabloSport Predator programmer. The combination of those modifications netted me almost 4 MPH HWY and just a little above 2 MPG City.
Also, it's been reported by the truck and the LX/LY Hemi powered car communities that with some mileage on the engine, MPG improves.
But a good start for you would be an intake and exhaust. As far as intakes go, don't get a cheapie off of eBay. The inlet tubes are thin-walled cheap plastic, they crack and the filters are junk. Some have even been reported to have come apart and filter material was sucked down into the engine. Not good.
There's a thread under the Modification Sections on the 5.7L HEMI intakes that are available. Cooler air creates a better, more efficient combustion cycle. That's because cooler air contains more oxygen molecules. One of our members, who is now full-time rv'ing it but still posts here, did a great job with comparing some of the intakes available.
Good luck!
Old 12-22-2011, 06:25 PM
Thank you Maddog for that information... will look at those sites. .. Have a Merry Christmas!
Old 12-23-2011, 12:33 AM
heathk2003's Avatar
heathk2003 heathk2003 is offline
Vehicle: 2012 Dodge Ram Laramie
heathk2003 is on a distinguished road
Give it a little time to break in and remember we are in winter blend gas season so mileage will suffer from that too!!
Old 12-23-2011, 01:12 AM
terb's Avatar
terb terb is offline
Vehicle: 2014 Ram 2500.........6.7
Rep:17
terb is on a distinguished road
Is it 4X4? What gear ratio do you have and what size tires are on it? Did you buy your truck from Dennis Dillon?
2016 1500 Laramie Crew Cab 6.4 Bed 3.92 Hemi
2016 2500 Laramie Crew Cab 6.7 Cummins
Old 12-23-2011, 01:22 AM
dixiejwo dixiejwo is offline
Vehicle: 2012 Ram 2500
dixiejwo is on a distinguished road
I've got about 1k miles on my 2012 2500 Hemi. With 360lbs of sand in the back I'm getting about 12.1 to and from work (secondary roads, rolling hills) and 18.5 on the freeway. In my experience nothing effects your gas mileage like your right foot...except maybe too much idling.
Old 12-24-2011, 03:56 PM
Iamahemi Iamahemi is offline
Vehicle: 2012 Ram Power Wagon
Color: PW7
Rep:58
Iamahemi will become famous soon enough
Your mpg is about average from what I have read on some other forums. I average about 14hwy & 12 city in my PW. I've got 4:56 gear ratio 33" tires. Isn't much difference with 4:10 gears, the 3:73 gears are gonna get you a little better mpg. I only have 1500 miles on my truck so everything is still pretty tight. I'm sure once things loosen up I might see a slight increase. All in all I think the mpg is pretty good for a truck this size.
2012 PW bright white,Leer cap,Bedrug,2010 rear headrest swap,black Mopar side steps, debadged
Old 12-24-2011, 07:52 PM
TNhemi12 TNhemi12 is offline
Color: Mineral Gray
Rep:18
TNhemi12 is on a distinguished road
I just filled up my 2012 today, I got about 11.2 MPG on the last tank
Old 02-08-2012, 10:43 PM
turbojoes turbojoes is offline
Vehicle: 2007 mega cab
Trim Level: laramie
Color: inferno red
turbojoes is on a distinguished road
I have an 07 mega cab with the hemi, 3.73 gear, 315's and i get 9-10 in city and 13 on the highway.
Old 02-08-2012, 11:08 PM
t00tall10169's Avatar
t00tall10169 t00tall10169 is offline
Vehicle: 2009 Dodge Ram 2500
Rep:19
t00tall10169 is on a distinguished road
at least im not the only guy with the same mpg numbers. i thought i was the problem but i guess these are the #s. good thing gas is cheap... not
