Old 09-11-2012, 09:54 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
unbroken if you remove the clutch fan and just keep the oem efan it's basically the same thing as replacing it with the v6 efan. Just make sure to keep the factory shroud. It isn't shrouded quite as good as the v6 efan but still works great. I've been using it like this for a long time in FL heat without issue. The fan itself is identical it's the shroud that is the only difference.
Sean
Old 09-11-2012, 09:59 PM
moparornocar72's Avatar
Rep:630
^ ditto, my electrical fan and shroud with the clutch fan removed has worked perfectly!
14.268 @ 95 MPH Full Trim
Old 09-11-2012, 10:10 PM
Moose612 Moose612 is offline
Vehicle: 2006 Ram 2500
Rep:26
Moose612 is on a distinguished road
Ok I don't have a solid understanding of the workings of the e-fan swap. So here are my questions.
1. I take the big mechanical fan/shroud of completely along with the ac fan and place this in where the mechanical went and plug it into the ac fan connector? that simple?
2. the oh so deadly heat. I live in el paso. Its f**king hot. Is it to hot? I do a lot of highway driving between el paso and albuquerque.
Thats about it.....I haven't seen a good write up on this so I never quite grasped the how to or workings of it. Also those that have done it with the '12s hows it working?
Living the dream.
Old 09-12-2012, 01:39 AM
E.L.D. 44's Avatar
E.L.D. 44 E.L.D. 44 is offline
Vehicle: 2011 Dodge Ram CC 4x4 Sport
Rep:388
E.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really nice
Unbroken, Timmy and I changed ours out the same day with aftermarket units and haven't had an issue. The swap is plug and play and it took 5 minutes. The stock fan and the V6 IS different! It is the same size but has a different pitch and moves a lot more air! With the v6 fan and a 180 degree tstat during the Oklahoma summer my temp never got above 183 with the a/c on. It would creep up a little if I stayed parked for a long amount of time, but when it hits 222 and the fan hits high speed holy cow it comes down FAST!
MY MOD THREAD
http://www.ramforumz.com/showthread.php?t=87541
Old 09-12-2012, 01:42 AM
E.L.D. 44's Avatar
Rep:388
Here is my write up from when I did it. Hope it helps.
http://www.ramforumz.com/showthread.php?t=108220
I had no problems during this summer and it hit 118 in OKC.
MY MOD THREAD
Old 09-12-2012, 01:47 AM
Ramfd's Avatar
Ramfd Ramfd is offline
Vehicle: 2009 ram 1500 QC 2wd
Trim Level: Big horn
Color: Brilliant black pearl
Rep:150
so how hard would it be to just wire in a thermostat switch set to 180 to the fan? add to that the 180 temp thermostat there should not be any issues, may be a bit of over kill, but the lower the temp the better.
Old 09-16-2012, 02:12 PM
Rep:26
Alright after reading E.L.D. writeup I think I have a good understanding. Correct me if I'm wrong. For the '12s being that there is no tuning the fan won't engage unless one of two things happens.
1. The temperature reaches the stock temp of 222?
2. The A/C is on?
So if this is the case to avoid reaching that high of a temp when sitting still or driving in slow traffic just turn the A/C on?
Living the dream.
Old 09-16-2012, 03:34 PM
snrusnak's Avatar
Rep:1385
moose that's correct.
It is highly recommended not to rely on your memory though, as everyone knows we often forget things and if you forget then your engine will be getting very hot.
Sean
Old 09-17-2012, 01:05 AM
E.L.D. 44's Avatar
Rep:388
The joys of getting old. ha ha
MY MOD THREAD
Old 09-17-2012, 08:22 AM
UNBROKEN's Avatar
UNBROKEN UNBROKEN is offline
Vehicle: 2012 Ram R/T
Trim Level: R/T
Rep:123
UNBROKEN will become famous soon enoughUNBROKEN will become famous soon enough
It's just a couple of wires to the fan...you can easily wire in a manual override switch to turn it on whenever you want...or tie in an aftermarket controller. It'll be downstream of the ECM so it shouldn't mess with the computer at all.
