Supporting Mods for Nitrous - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion > Nitrous Discussion
Nitrous Discussion Questions and Answers regarding adding Nitrous Oxide to your Dodge Ram.
Old 12-23-2011, 01:21 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Question Supporting Mods for Nitrous
Spent my day off looking through the Nitrous section, and have been tossing this idea around for a while. I am leaning toward the TB plate wet kit from Nitrous Outlet...sounds like the best bet for the hemi and an easy way to do it. Plus it would be much easier to NOT drill the Vararam I have now.
A couple questions to throw out:
What needs to be done to help preserve the drivetrain.
Can I run it with the stock 3.21 open rear?
Do I need a higher stall converter first?
Will the stock tranny handle it?
I am wanting to change the gears and add an LSD and do some tranny work, like a Transgo HD2. The motor only has 17000 miles, and I have read that nitrous and newer motors arent a good combo, so when is it safe to add nitrous. I will only run 75 until I get all the other stuff in line to match the spray....thanks in advance!
Old 12-24-2011, 11:11 AM
05ram's Avatar
05ram 05ram is offline
Vehicle: 2004 VW .:R32, 3.2l AWD V6
Trim Level: .:R
Color: UGM
Rep:145
05ram will become famous soon enough05ram will become famous soon enough
You can add a progressive controller to it which will gradually add the N2O instead the whole shot at once which will be easier on the entire drivetrain. All the Hemi's can handle a 75 shot all day.
2008 VW .:R32, 3.2l, AWD, V6, #2952/5000
Old 12-26-2011, 03:56 PM
916Timmy's Avatar
Rep:1443
Thanks man! I'll look into that...I did read about that window switch. Is that the same thing or no?
Old 12-26-2011, 05:19 PM
05ram's Avatar
Trim Level: .:R
Color: UGM
Rep:145
I think the window switch lets you set a minimum and max rpm for injecting, thats different than the progressive controller.
Old 12-26-2011, 07:42 PM
916Timmy's Avatar
Rep:1443
Thanks again! It's gonna be a bit for the spray comes, so I'll definately ask around!
Old 12-26-2011, 10:52 PM
Rep:3347
The window switch is very straightforward, set your low RPM turn-on and your high RPM shut-off, it's the simplest way to do it. The progressive controller takes more fine tuning to get it right and you'd only really need it if you were having traction issues. I've got my window switch set at 3000 RPM and 5500 RPM so with my 2800 stall I'm almost spraying out of the hole with no traction issues. The N-O plate system is nice and clean, I've got one coupled with a ZEX kit off of a chally, and I use the N-O pill chart, not the Zex one, the ZEX one is measured at the crank so it's not a 100hp shot at the wheels.
As for your drivetrain, you should be fine with your mods. I would still recommend looking at a new gear ratio though, my 3.55s just hurt so I can only imagine your 3.21s. You've already got the line pressure booster, so you've done pretty much all you can to your tranny until they come out with a shift kit.
One mod you could look at is a meth injection system, this would allow you to not pull timing when you spray, but make sure you run a separate tune for it that you unload when you leave the track because if you ever lose your meth injection then you're looking at causing troubles for your motor.
Old 01-06-2012, 08:48 PM
AllUCIsTailLights's Avatar
AllUCIsTailLights AllUCIsTailLights is offline
Vehicle: 2007 Dodge Ram
Trim Level: 1500 Big Horn
Color: patriot blue
Rep:39
AllUCIsTailLights is on a distinguished road
getting my spray kit and installed by the end of this month cant wait!
Old 01-07-2012, 06:33 PM
916Timmy's Avatar
Rep:1443
What did you end up going with? I was talking to my 700HP Chally friend today about putting a plate kit together! Forward motion! He has a ton of spare parts, enough for three full kits he says.
Old 01-12-2012, 12:31 PM
Color: patriot blue
Rep:39
im going with the nitrous express kit comes with new and improved plate
Old 01-14-2012, 09:18 PM
916Timmy's Avatar
Rep:1443
I saw that NX kit, thats probably what I will get too, My buddy Rick (700HP Chally) says that NX has the best/most reliable solenoids!
nitrous hemi
