Old 12-23-2011, 07:23 PM
mikeb33's Avatar
mikeb33 mikeb33 is offline
Vehicle: 2012 1500 CC Express 4WD
Trim Level: Crew Cab Express
Rep:14
mikeb33 is on a distinguished road
Default Cut my rear springs today!
I know I'm not the first, but I'll talk about it anyway.
I jacked it up by the pumpkin and put jack stands under the rear frame, then took the wheels off. I removed the lower shock bolts and started lowering the axle. I got to the point where the brake lines were almost taught and was just able to pry the springs off.
I cut 1.5 coils with an electric die grinder. The left and right have different part numbers. Here is the cut and uncut:
Before the rear was at almost 40":
After reassembly the rear is about 38":
Before:
After:
The carnage:
2012 Express CC Black 4WD 3.92 Posi, Bedrug, Backflip G2, Cut rear springs, V6 fan mod, 180 thermo, Diablo Sport
Old 12-23-2011, 07:31 PM
mikeb33's Avatar
Rep:14
I would say it dropped about 1.75", but will probably level out more since I only have 500 miles on it. I've had it for 8 days and haven't even been able to was it yet (obviously), due to it being 35F outside.
Old 12-26-2011, 01:17 PM
hammer horn's Avatar
hammer horn hammer horn is offline
Vehicle: 2011 dodge ram
Trim Level: bighorn slt
Rep:41
hammer horn is on a distinguished road
you not worried about your warranty?
Old 12-26-2011, 02:41 PM
mikeb33's Avatar
Rep:14
Warranty on my springs?
I have an updated picture where it is NOT filthy.
Old 12-26-2011, 03:01 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Looks pretty good! Nice level stance!
Old 12-28-2011, 06:01 PM
5.7ram's Avatar
5.7ram 5.7ram is offline
Vehicle: 2010
5.7ram is on a distinguished road
pretty dam good.
2011 Dodge Ram CC Sport Hemi. / 4300 Hid's Top & Bottom / Tints / 24' Kmc Slide's w Toyo's / BellTech 2/4.
Old 01-15-2012, 10:16 PM
FlashSmith101's Avatar
FlashSmith101 FlashSmith101 is offline
Vehicle: 2009 Dodge Ram 1500 Sport Hemi
Color: Electric Blue
Rep:23
FlashSmith101 is on a distinguished road
how did you even measure out how much you should cut off the spring??
Mods- Diable Predator Sport (set on 91 octane), Air Raid CAI, Aero Turbine exhaust, 24in Boss Motorsport rims (painted white), Cut back springs(leveled), color matching blue dash and features, white emblems and grille, 180 t stat, P.A. system, all LED lights.
Old 01-15-2012, 10:47 PM
mikeb33's Avatar
Rep:14
I read a few other posts where they started at 1 coil and ended up doing more. Other than that, it was a guess.
Old 01-16-2012, 12:24 AM
lasilver lasilver is offline
Vehicle: 2011 RAM 1500 Sport
Color: Blue
Rep:12
lasilver is on a distinguished road
All you did was cut the rear springs? The whole truck looks lower . Did you notice any vibs from the drive train after lowering the rear?
Old 01-16-2012, 06:57 AM
mikeb33's Avatar
Rep:14
Just cut the rears. No issues at all. It can't be any different than if you put some cargo back there.
