Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Tuning Discussion > Diablo Predator Questions & Info!
Place your Ad Here!
Old 12-24-2011, 12:18 AM
beermanjoe's Avatar
beermanjoe beermanjoe is offline
Vehicle: 2007 Ram
Rep:25
beermanjoe is on a distinguished road
Default Oil Change
Think I should go back to factory tune when I take it in for an oil change?
Old 12-24-2011, 01:56 AM
Zlow28's Avatar
Zlow28 Zlow28 is online now
Vehicle: 2007 Ram 1500
Rep:19
Zlow28 is on a distinguished road
I definately would. Not that it should matter, but i like to play it safe
Rep:2910
for an oil & filter change only ?
they don't need to hook up their computer to do that
do you have an extended warranty on your 2007
regular warranties are usually only good for 3 years or 36 months
some newer ones have a 5 year or 100,000 mile warranty
i don't know what your warranty covers, when the warranty is at its life term, it should not matter if you modded it or not
Old 12-24-2011, 09:55 PM
beermanjoe's Avatar
Vehicle: 2007 Ram
Rep:25
It has an extended warranty. Worried about them thinking they need to flash the computer. Don`t want loose my DS tune.
Old 12-24-2011, 10:11 PM
MADDOG MADDOG is offline
Rep:22
I always return mine to stock before I go to the dealer. They may check your PCM to verify software versions or possibly to flash an update that is available.
Old 12-24-2011, 10:33 PM
Zlow28's Avatar
Rep:19
just set it back to normal. Its very easy for a reason, take advantage of it.
Old 12-24-2011, 11:55 PM
beermanjoe's Avatar
Vehicle: 2007 Ram
Rep:25
Back to stock Monday morning!
Old 12-25-2011, 03:31 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
For the reasons stated my MADDOG, return to factory.
NOTE - After you have returned it to factory, IF they hook up for any reason, they may ask you if you have a tuner. THEY CAN'T TELL, and don't let anyone convince you otherwise. What they can tell, is that the PCM has been flashed, and the most logical reason would be if you had a tuner.
What should I do???
Easy! After installing the factory tune and verifying it's OK (take for short drive), disconnect the battery cable to perform a full reset. The cute little code that indicates the PCM has been flashed is gone.
brad
Interested in one of my mods?
