Old 12-25-2011, 05:45 PM
BlackBullet's Avatar
BlackBullet BlackBullet is offline
Vehicle: 2010 Ram Hemi TRX4
Trim Level: TRX4
Color: Brilliant Black Met
Rep:39
BlackBullet is on a distinguished road
Default remote start failure!
anybody know what would cause this and how can i fix it? got plenty of fuel...
Leveling kit, DSP tuner, 14" MAGNAFLOW with side exit, heavy duty DODGE slush mats, DODGE bed mat,BILLET TECH catch can, STAINLESS steel door sills, K@N drop in filter, level ride airbag suspension....
Old 12-25-2011, 06:09 PM
LC Hauler's Avatar
LC Hauler LC Hauler is offline
Vehicle: 2014 Ram 2500 Laramie
Color: Bright Metalic Grey
Rep:72
LC Hauler will become famous soon enough
might be tempurature related. Mine won't start sometimes of the climate or engine is too warm.
You will know if this is the case if you only here 1 honk when you hit the auto starter.
Old 12-25-2011, 07:33 PM
Rambunkshuss's Avatar
Rambunkshuss Rambunkshuss is offline
Vehicle: 2014 Dodge Ram
Rep:87
Rambunkshuss will become famous soon enough
Have you ever replaced the battery in the key fob since it was new...?
Life`s tough, its even tougher if you`re stupid
Old 12-25-2011, 08:33 PM
Ironsides Ironsides is offline
Vehicle: 2009 Dodge Ram 1500 CC 4X4
Trim Level: SLT Big Horn
Rep:44
Ironsides is on a distinguished road
The EVIC should display what the problem was when you get into the truck. What did it say?
Old 12-25-2011, 09:41 PM
Trim Level: TRX4
Rep:39
it did say "auto start aborted" but i did not see the reason. maybe i got into the truck too late
Old 12-25-2011, 09:42 PM
Trim Level: TRX4
Rep:39
battery has not been changed but everything else works and the EVIC says auto start aborted
Old 12-25-2011, 09:50 PM
LC Hauler's Avatar
Rep:72
sounds like a temp issue then, mine said the same thing the other night, it was warm outside.
I did some digging around, if you have your heater on to blow warm air when cold, heated seats on and heated steering wheel, if the outside temp is warm the truck will not autostart. Just the same in eht Summer of the truck is set to A/C and seats are on, and the temp is cool the truck will not start either.
did you hit the remote start again? if you get 1 horn honk, then the truck will not start on remote start.
Dodge did this to prevent issues and catostrohic failures and burn downs.
try this - turn the inside heater fan speed to off, and then retry the remote starter.
Old 12-26-2011, 12:17 PM
Trim Level: TRX4
Rep:39
and just like that, remote start operational again. trucks too smart for me i guess
