Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel
Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 12-26-2011, 01:09 PM
adotson2009 adotson2009 is offline
Vehicle: 95 dodge ram 2500 4x4
Trim Level: laramie
Color: red
adotson2009 is on a distinguished road
Default swappin v10 with 12 valve cummins
i have a 95 ram with v10. what do i need to do to put a cummins in it? i know i need the motor an intercooler but what else?
Old 12-26-2011, 11:04 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Fuel pump, bell housing, motor mounts
It's really not an easy swap and not really worth it since you can just purchase a truck with one in it for typically cheaper then what you'll have into the swap
Old 01-05-2012, 04:46 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Transmission valve body will need reprogramming for different rpm range. Different torque converter. Agreed, look around and find a Cummins truck in good shape. Cheaper and then you have all that time to do other stuff like sell your gasser.
Old 01-05-2012, 04:49 PM
crusher's Avatar
crusher crusher is offline
Vehicle: 2014 ram sport crewcab rambox
Rep:363
crusher is just really nicecrusher is just really nicecrusher is just really nicecrusher is just really nice
suspension too, the diesel engine a normally more heavy
also look to make sure it bolts to your current transmission, maybe you will have problem with that
2014 ram sport crew cab with ram box,side steps,sport hood,remote starter,8 speed &3.92 gear lsd,4 corner air susp,knn intake,mufflex 18, BT catchcan,bakflip F1 cover
