Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Towing 3rd Gen Dodge Ram Towing Questions
Old 12-27-2011, 12:10 PM
lgracia's Avatar
lgracia lgracia is offline
Vehicle: 2007 dodge ram 1500 sport
Trim Level: 1500 sport with Hemi
Color: sunburnt orange
Rep:22
lgracia is on a distinguished road
Default towing with 07 RAM 1500 sport
Hello all, just a quick question, have an 07 1500 5.7 RAM Sport with tow package (type III hitch) auto trans with tow/haul button and a 3.92 limited slip diff as well as 20 inch tires. I was think of putting a 5th wheel hitch into the bed (short bed) to tow a 5th wheel trailer. Will the 07 1500 be able to handle a 5th wheel trailer? I don't have one yet but am thinking about getting a 25 ft light weight (less than 8k lbs) would welcome any advise you can give.
Thanks
Old 12-28-2011, 11:06 PM
06dodge1500's Avatar
06dodge1500 06dodge1500 is offline
Vehicle: 2006 Dodge Ram
Color: Tan
Rep:13
06dodge1500 is on a distinguished road
A 2007 5.7 liter is rated to tow 9100k pounds so you can pull the trailer weight with your pickup. Towing a 5th wheel with a 1/2 ton is not recommended though as it does not have the same heavy duty axe, spring, frame, ect. as the 2500 or 3500. Saying that I have seen it done. I guess if you were to upgrade brakes, add more leaf springs and air bags, and get an adjustable sliding 5th wheel hitch you could do it. Your owners manual will tell you the maximum towing capacity. You also have to figure the 8k pounds is just the trailer if you add clothing, kitchen items, ect. in the trailer and pickup the weight will go up. I wouldn't suggest it but it can be done. Would be interested though to see pictures of it and hear how it handles for you if you do it.
Old 12-29-2011, 09:51 AM
lgracia's Avatar
Rep:22
Thanks for the input, I still have some thinking to do regarding the 5th wheel, will keep you all posted.
Old 02-25-2012, 06:35 PM
Bounderbob35's Avatar
Bounderbob35 Bounderbob35 is offline
Vehicle: 2012Dodge Ram 1500
Color: Deep Cherry
Bounderbob35 is on a distinguished road
I also have a 2007, 5.7 auto with 392 gears 160,000 miles on it and i pull a 35ft trailer with 2 sliders. About 8100lbs loaded and have no problem pulling it. Have 3000 lb supersprings, magna flow system and a K&N. gets around 8 to 11 mpg
