Old 01-30-2012, 09:19 PM
bculle1 bculle1 is offline
Vehicle: 2010 dodge ram
bculle1 is on a distinguished road
Originally Posted by rtkman View Post
I used a bypass found on youtube by soundman car audio. It worked awesome. Mine is bypassed. Let me know if you need any help with wiring i have it all wrote down what went where...
I was just curious if you had any tips on the bypass for your Avic. Im installing mine tomorrow. I already swapped the yellow mute wire and moved it 1 pin up. From there Im a little bit confused. I believe I am then supposed to connect the mute wire, ground wire and parking break wire together then then ground all of them once connected. I know that was confusing haha. Id appreciate the help.
Old 01-30-2012, 10:26 PM
rtkman's Avatar
rtkman rtkman is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Rep:167
rtkman has a spectacular aura aboutrtkman has a spectacular aura about
You are correct connect them all together. They don't ground to the body. Just connect them all.
Enjoy the head unit. I love mine! I just installed a 4 channel amp and my speakers will be here tomorrow.
Old 02-02-2012, 01:49 PM
garcia0106 garcia0106 is offline
Vehicle: 2012 Ram Express Crew
garcia0106 is on a distinguished road
Default Speed Signal Input
Did you connect the (pink) speed signal cable? If you did where did you tap into the speed sensor?
Also did you connect the Orange illumination cable? If so where did you tap into that?
Thanks in advance
Old 02-02-2012, 07:27 PM
rtkman's Avatar
Rep:167
The pink on the Pioneer harness goes to the purple/white wire on the pac harness. The orange/white wire on the Pioneer harness goes to the Orange/white on the PAC harness. All of the connections are made between the Pioneer and the PAC harnesses. You dont "tap" into the harness on the body at all. When you are done you should be able to just unplug the main plugs and return the vehicle to stock instantly with no disturbed wires.
