map lights - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 12-28-2011, 11:21 AM
jammons5126's Avatar
jammons5126 jammons5126 is offline
Vehicle: 2012 Dodge Ram 1500 Crew Cab
Color: Mineral Gray
Rep:49
jammons5126 is on a distinguished road
Default map lights
ok so i am trying to put LEDs in my map lights but i dont know how to take the whole thing out without damaging something. does anyone know how to do this?
Old 12-28-2011, 08:32 PM
royw's Avatar
royw royw is offline
Vehicle: 2011 Dodge Ram
Rep:39
royw is on a distinguished road
Slip something like a thin standard screwdriver in at the hinge point. Gently pry. May need to option off on sides.
Don't feel bad, I tried three times before seeing a video (on a different brand car) that gave me the hint.
I'm not a fan of hidden connections where you need a manual (AFAIK non-existing) just to take most interior and even the tail lights off. What ever happened to the good old visible screws to hold things together?
Old 12-28-2011, 08:42 PM
Shield Shield is offline
Vehicle: 2011 Dodge Ram 1500
Trim Level: Big horn
Color: Blue
Shield is on a distinguished road
I found a video when I was doing mine because I also did not want to screw it up. I cant find the video now, but this might help. I'll post the link if I find it.
http://www.ehow.com/how_6755667_repl...-ram-1500.html
Old 12-28-2011, 11:04 PM
Color: Mineral Gray
Rep:49
Ok so I got the whole thing off but how do I get to the lights itself. The wires are short so it makes it difficult to unclamp the wires.
Old 12-29-2011, 04:58 AM
col's Avatar
col col is offline
Vehicle: 2012 Ram 3500 CCSB
Trim Level: Laramie Longhorn
Color: Black & Gold
Rep:92
col will become famous soon enough
All you do is pop the plastic lense off. Stick some electrical tape to the bulb & pull it out, then just push the new Led's in..Dont have to remove the whole thing.
2012 3500 Cummins Laramie Longhorn CCSB | 68 RFE | Black over Gold | RaceMe Pro Tuner | Flo pro 4" Stainless Steel Turbo Back Straight Exhaust | 5'' S/S Tip
Old 12-29-2011, 06:30 AM
royw's Avatar
Rep:39
Electrical tape! So brilliant! So obvious! So not me!
After a half an hour of trying every which way to grab the bulb (even went so far as to try to remove the whole overhead console but could figure out how to release half of the blind connectors) I very carefully removed mine using a pair of pliers. Luck was with me that day and the bulbs did not break!
Damn, electrical tape! Gotta remember that trick...
Old 12-29-2011, 07:44 AM
Color: Mineral Gray
Rep:49
I took the plastic lens off and switched the lights but now another problem has arised. The lights wont turn on when I click it. Damn this console.
Old 12-29-2011, 08:09 AM
Color: Mineral Gray
Rep:49
Nvm. It's fixed
Old 12-29-2011, 01:33 PM
col's Avatar
col col is offline
Color: Black & Gold
Rep:92
Nice....now you can see properly.
Old 12-29-2011, 07:29 PM
Color: Mineral Gray
Rep:49
It was halfass in my truck. The map lights were stock and the rear was led. Now it looks good.
