Old 12-28-2011, 04:43 PM
Trucks n Guns's Avatar
Trucks n Guns Trucks n Guns is offline
Vehicle: 2007 1500 QC 4x4
Trim Level: SLT Thunder Road
Rep:48
Trucks n Guns is on a distinguished road
Default 5100 Leveling: What do I need
Took the 07 Hemi in for inspection today. It needs a battery and the left front strut it leaking (50k miles). I was already considering installing the Bilstein 5100 adjustables and figured that since the struts need to be replaced anyway, this is the perfect time.
Local oil change/tire place I took it to said that I need a kit to install the 5100s and that their only for trucks that already have a lift kit. All the reading I've been doing says different and the prices they want for a stock strut are more than the 5100s I've been seeing online.
I found a local guy who will install both for under $200 and just want to make sure that if I order 2 x part # 24-186988 there won't be any install issues other than an allignment being needed.
Bilstein 5100s - Magnaflow 18" muffler - Volant CAI - 276/65R20 Cooper Zeon LTZ - APC LED Bar
Old 12-31-2011, 02:58 AM
ScatPak07's Avatar
Rep:970
The guy you saw the first time was a retard haha. You do not need to have anything before you install the 5100s or need a kit to do so. All you need to do is order them and install them. I would say not to go back to that guy since he does not know what he is talking about. They should take about a couple hours to install them so the $200 doesnt seem to bad. And yes you will need an alignment after you install them. Good luck with it man
