Old 02-29-2012, 08:26 PM
ruban ruban is offline
Vehicle: 2010 dodge ram 1500
Color: grey
ruban is on a distinguished road
Default dodge help
hi there . im looking to do 6 inch lift with 37 inch tires. what kind of gas mpg u lost with 37 inch tires and is realy heavy on truck.
Old 02-29-2012, 08:29 PM
Color: grey
whats the big difference between 35 and 37 inch tires on 1500 . is there big drop in gas mileage and is 37 too heavy on truck....
Old 03-01-2012, 11:17 AM
bodhi bodhi is offline
Vehicle: 2011 Ram
Rep:23
bodhi is on a distinguished road
quick probably stupid question but I have my truck leveled already… do you leave the level kit on when adding a 4 or 6 inch lift kit or remove it.
Thanks hopefully not to obvious of an answer
Old 03-01-2012, 02:26 PM
Rayne's Avatar
Rayne Rayne is offline
Rep:73
They should remove it.
Old 03-06-2012, 12:22 PM
LeKy411's Avatar
LeKy411 LeKy411 is offline
Vehicle: 2011 Ram 1500
Color: Blue
Rep:100
LeKy411 will become famous soon enoughLeKy411 will become famous soon enough
Originally Posted by cabindoor00 View Post
Thanks. I was figuring that the warranty would be voided, but I've seen with other manufacturers that the warranty wouldn't be voided if you had the dealership install it. I'll just hold off a while before I decide to lift the truck, I guess.
Your warranty will be void in all aspect regarding the lift and anything that directly relates to it and can fail through the addition of the lift. Even if your dealer installs the lift, you will not maintain your warranty through a 3rd party part addition. The only exception is the Mopar Lift which is really a Super Lift with a Mopar sticker.
Most dealers do not install custom parts and don't want liability of such work because then you get into the fine line of "since dealer installed, it should maintain warranty". Your best bet is to get it done at a well known off road shop. They have much more experience and will do a much better job than your dealer who may have little to no experience with lifts.
Even if you install the lift and then your window motor goes bad, the dealer cannot state it is due to the lift and will have to repair it. Now if your wheel bearings go bad for whatever reason they may attribute it to the larger tire size and lift. Some dealers are more felxible while others are rigid on warranties. Depends where you go.
