Battery Drain - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 12-29-2011, 08:58 PM
butterblizz butterblizz is offline
Vehicle: 2008 Dodge Ram 1500
Trim Level: TRX
butterblizz is on a distinguished road
Default Battery Drain
my truck is having problems starting, now that is finally getting cold, i have instaled some hella driving lights and reverse lights. i had the battery tested and could not test because only had 20% on it. they told me to see if it was pulling any from it and i tested it with it pulling 11.62 amps, i pulled off the stuff i had installed but only went down to 10.82 and that was the trailer brake controler. any help with this or if you think the battery is bad.
Old 12-30-2011, 12:48 AM
06dodge1500's Avatar
06dodge1500 06dodge1500 is offline
Vehicle: 2006 Dodge Ram
Color: Tan
Rep:13
06dodge1500 is on a distinguished road
How big is your pickup battery? If it is not big enough and you are drawing more amps than what it is rated you can be draining the battery fast. I would buy a new battery because the one you have is obviously shot and make sure you let the parts person know that you are drawing whatever amps you are drawing while at rest. Here is an interesting website that will tell you about car battery amp.
http://www.chem.hawaii.edu/uham/bat.html
Old 12-30-2011, 01:08 AM
Rep:2929
your alternator should be stepped up if it is less than 160Amp & your battery should be 650 to 700 Cold Cranking Amps ( CCA )
If you go to any auto parts store they can test your system, just give your battery a charge before you go
Personally i go to an Auto Electric shop & let them tell me what i need, for my preferred set up, my rotating lights really draw the juice.
Old 12-31-2011, 12:17 AM
Trim Level: TRX
it is the factory battery, with 650 cca
Old 01-07-2012, 04:49 PM
dkitt10 dkitt10 is offline
Vehicle: 2007 Dodge Ram 1500 TRX4
Trim Level: TRX4
Rep:17
dkitt10 is on a distinguished road
maybe you have a short somewhere, try pulling fuses to see if something is drawing too much??
battery
